Hello all,
I have been working on what I believe to be an ignition problem for quite some time. I made the decision that it is an ignition problem based on some of the great posts in this forum. My spark is very weak. There is no way it will jump 7/16" I can barely see it on the spark plug when grounded to the engine. I have run all the ohm checks in my manual and they appear ok. I live in a place where I can not obtain a DVA meter to test the output of the stator and I do not have a timing light to check for intermittent spark at the plug wires. The question is, can I use an O'scope in the place of a DVA and what would the signal look like? I assume it would be pulses of roughly 400v. My scope is capable or reading that. Has anyone done this before? I am hoping to do some testing and isolate something before going down to New Zealand in a month.
