Did you perform the 180 second oil transfer test?
Make sure the remote tank is at leats 1/2 full, with the key on and engine off cut the tie strap and carefully remove the water trap from the engine tank,drain the tank into a container until the alarm sounds then reattache the water trap.
at this point you should have an audible,3 bars flashing and the oil transfer pump on.
the engine tank should refill and shutoff in 180 seconds or less.
anything longer than 180 seconds means there is either a restriction or low transfer pump voltage.
http://forums.iboats.com/showthread.php?t=171276
http://forums.iboats.com/showthread.php?t=140400
