I have a leaking oil tank when the '99 90 Merc is trimmed up. Looks like the inside of the tank neck is hammered so I ordered new tank and cap o-ring. My question is looks like there is a lower mounting bolt that requires removal of lower cowl. Anyone have tips/suggestions for the job? I am fairly mechanically inclined but 1st OB boat I have ever owned. I also ordered a factory manual for it so hopefully that helps. I was planning on running boat on stand alone fuel tank @ 50:1 for a while to make sure oil system is bleed out. Required?
