Re: 1996 Mariner hard starting
One hour shut down is NOT stone cold.
A stone cold start procedure often results in a flooded motor.
Try Opening the throttle about a quarter, choke just a heatbeat while cranking, just enough to fire then maintain fast idle 1800 - 2000 with the throttle. If the motor slows, then momentarily, and I mean just a heatbeat, bump the choke again. Maintain the RPM until it builds enough heat in the cylinders that the RPM begins to rise, pull the throttle back just a bit to maintain the 1800 - 2000 for about two minutes. Slowly pull the throttle back to a stable idle.
