Re: hard starting
a further comment.....
it takes three things to make an engine run. fuel, spark(ign.) and compression.
see if there's fuel present by looking down the carb venturi while actuationg the throttle. there should be a stream of fuel coming out the accelerator pump nozzles.
check ign. sys. remove coil wire from tower on dist. cap. hold near ground and check for spark while cranking eng. repeat with ea. sparkplug wire. causion should be observed during this test. be sure to run blower and have a sniff prior to creating a spark. ya don't wanna go boom. or get a spark plug tester..... (after reading about your excessive fuel present. ya may wanna get that corrected prior to making any sparks at all. i'd worry about creating a spark with that much fuel present)
do compression test...
I turned it off and looked down the carb and it looked like there was a river flowing.(fuel)
sounds like ya've narrowed it down to over rich to me.
a few items to check might be.... right outa the book....
warm engine carb percolation (fuel boils out of the float bowl when shut off and warm, floods intake manifold)
clogged fa
auto choke not opening
float adj.
float leaks or is saturated w/fuel
needle and seat leaking
carb. gasket leak
excessive fuel pump pressure (would unseat needle and seat)
cracked or porous carb body....
still ya might check the dwell and timing. i had to reset mine mid season. my dwell had moved for some reason.....
