I recently replaced the reed box gaskets and the gaskets on both sides of the intake manifold to fix an issue with carbs spitting back. The engine starts and runs much better at the high end. Unfortunately the engine idles at 1200 to 1500 and won't come down even after warming up.
-I've double checked the seals and reassembled with a thin bead of RTV.
-Checked my idle timing (6 degrees).
-Checked the throttle bodies to insure they are fully closed at neutral.
-Capped off all intake vacuum ports that need to be capped.
The engine continues to run at speeds of 1200 - 1500 rpm. It will many times proceeds to sneeze and sputter when put into gear. With minimal throttle advance it stalls. With a jump to 1/2 or 3/4 throttle it will accelerate great.
I assume it is getting access air causing it to idle high and possibly lean.
Any suggestions?
Any suggestions?
