  #1
Old December 24th, 2008, 10:03 AM
Pacific Lots Pacific Lots is offline
Default Evinrude 175 overheat now STUCK flywheel need help
Hey all,
I posted a while back with my overheated Evinrude 175 year 1985, short story, replaced impeller, t-stats, head gaskets, etc and she runs again. However the rectifier/regulator was also damaged in the overheat and now won't charge and eats up 12 volts as soon as battery swith is turned on. So I posted and found a new rectifier but it is located under the flywheel which has not been off that motor since I was in college. I am not a novice so here is the story so far.
Removed top nut and soaked shaft in PC Blaster overnight. Installed pro grade puller with grade 8 bolts and hardened steel washers on top side of bolts. Tightend with wrench and tapped on flywheel. No budge. Put electric impact wrench on puller and tightened, more pc Blaster, left under pressure over night, next morning tapped puller, no luck. Took pneumatic air impact wrench to puller, tightened, lifted flywheel with harmonic fork, tapped shaft, no luck, banged shaft. Heated (I was careful) flywheel with propane torch to too hot to touch, tightened puller further with air impact, banged shaft, no luck. Tap Tap Bang Bang Bang Bang Whack Whack Whack with progressively bigger hammer, now up to 2 pound sledge. Four days now, trailered boat to marine mechanic and put acetelyne torch on flywheel, whack whack, no luck. Today we plan on OVERHEATING FLYWHEEL but before I completely ruin the whole thing, does anyone have an idea on how to get this thing off. I am considering cutting with a cut off saw until I have enough to split the flywheen with a cold chisel. So far I have also sheared one grade 8 washer, now have washers and SAE washers above. Any ideas or suggestions?
  #2
Old December 24th, 2008, 10:26 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: Evinrude 175 overheat now STUCK flywheel need help
some times it just takes time. overheating the flywheel will warp it. and have to be replaced. you are not suppose to hit the flywheel either. keep tightening, and a couple of raps on the center bolt. no prying flywheel either. it will go bang sooner of later.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old December 24th, 2008, 05:17 PM
James R James R is offline
Master Chief Petty Officer
Cool Re: Evinrude 175 overheat now STUCK flywheel need help
Follow Tashasdady's advice. It works. That how I do my problem motors.
  #4
Old May 13th, 2009, 02:28 PM
Aderondacker Aderondacker is offline
I have a 72 Johnson 50 hp that I made up a press using 20 ton hydraulic jack. Snaped a grade 8 bolt and bent a 3/4" thick 8" circular plate. Flywheel did not move. I believe the flywheel turned on the key. Before it seized on I also had the flywheel off two or three times the week before checking out the stator and pickup. Did the original poster get the flywheel off? John
  #5
Old May 13th, 2009, 06:33 PM
jonesg jonesg is offline
Quote:
2 things you can try, if its looking like you might have to trash the flywheel,
clip the anode of a mig welder to the outter rim, set it on the low amp and touch the crankshaft with the gun tip. (unplug any onboard computers first)
the other thing is drill an 1/8th inch hole through the flywheel next to the crankshaft to relieve the stress. After it comes off tap the hole and red loctite a bolt in there, cut the head off the bolt and grind it flush.
  #6
Old May 13th, 2009, 11:41 PM
jonesg, I was thinking of using my carbon torch. I would put the ground clamp on the flywheel and the carbon in my stinger. I have a AC/DC welder. I assume that DC- would be best. Should I try this with the puller on with pressure
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1983 evinrude 175 flywheel torque Benny1963 Johnson & Evinrude Outboards 6 May 26th, 2008 03:58 PM
1983 evinrude 175 flywheel torque Benny1963 Johnson & Evinrude Outboards 3 May 22nd, 2008 03:15 PM
Overheat Warning On 210 Merc Sportjet- Need Help! Downunder Mercury & Mariner Outboards 6 February 5th, 2008 09:35 PM
I need some help. Overheat alarm only @ WOT. mcgurk34 Mercury & Mariner Outboards 42 June 17th, 2004 07:32 PM
175 evinrude flywheel stuck derekdd Johnson & Evinrude Outboards 2 May 13th, 2002 10:49 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
