Re: Mariner 100 damaged piston (see pic)
There appears to be a very high amount of carbon build-up on this piston. So much so it would appear the rings are stuck in the ring grooves. The burned area of the piston as Laddies indicated, would point to a lean condition, probably caused by a malfunctioning carb. But normally, a burned area of the piston such as this would not be carbon covered so this was apparently an issue that existed for at list a short time. The fact that the rings are not destroyed means the engine could have run fairly well until a compression leak occured between the inside edge of the rings and the piston. In my opinion, this did not just occur. It has been in the making for some time.
