  #1
Old December 23rd, 2008, 04:16 PM
youngun1916 youngun1916 is offline
Thumbs down Aluminum boat leaks
Hi guys, I have an old aluminum boat with some cracks in the bottom from dragging over and hitting rocks. Have any of you ever used JB marine epoxy to repair?
  #2
Old December 23rd, 2008, 04:43 PM
Bond-o's Avatar
Bond-o Bond-o is offline
Master Shipwright
Default Re: Aluminum boat leaks
Ayuh,... It Works,..... Sometimes..... Got any Pictures,..??
There's Many Degrees of Damage,.....
__________________
Any Grease is Better,..... Than No Grease at All.......
NO PM's (Private Messages) regarding boat/engine problems. That is what these forums are for.
They will be Deleted
  #3
Old December 23rd, 2008, 04:48 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
i have used it with great success in accessible areas. pictures would help.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #4
Old December 23rd, 2008, 08:30 PM
tmcalavy tmcalavy is offline
Consider that option, and a coat of Gluvit inside when that's done.
  #5
Old December 24th, 2008, 06:34 AM
5150abf's Avatar
5150abf 5150abf is offline
My buddy uses a small jon for hunting and drags it with the same result.
I took it into work and welded the cracks then welded on some thick aluminum angle on the spots that rub, you should be able to have the same thing done to yours.
I am a JB junky so I wouldn't have a problem with that either, just make the repair alot wirer than the crack and kinda thick.
If you can find some you may even JB some angle on it.
__________________
GO IRISH!!!!
  #6
Old December 24th, 2008, 08:21 AM
martinrab martinrab is offline
Aluminium is easy to work but not that easy to weld. Best bet if you continue to use the boat that way weld some thicker aluminium plates on the spots where you hit it most. Have the hull a bit thicker and you will be good for a long time. Patchwork is always more expensive in the end as you have to do it over and over again.
I know from my old boat. A 14m aluminium sail boat. We patched some stuff after we hit a big chunk of wood and the patchwork had to be redone after only 3 months. Better to weld in the first place and have it done forever.
__________________
Walk a mile in my flip flops ... and bring me back a beer.
Cya around
  #7
Old December 24th, 2008, 01:37 PM
Thanks, sounds like the same problem. The crack is at the end of a piece of angle welded earlier. The problem with welding aluminum is it is always thinner at the edge of the weld.
  #8
Old December 24th, 2008, 01:52 PM
Indeed.That's what I meant. If you make parches you will always have problems again. So what I meant to say is to take a big chunk and protect the whole bottom part where you hit most. Don't know how big your boat is but normally it is worth the hassle. It is easy to work it into a certain form as you have a formed hull already and then weld the edges which have to be in not strained areas.
__________________
Cya around
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
3M Scotchkote for aluminum leaks John Lapic Boat Topics and Questions (not engine topics) 1 January 29th, 2008 07:55 AM
Aluminum boat leaks? GatorMike Boat Topics and Questions (not engine topics) 5 May 3rd, 2006 06:42 AM
test aluminum gas tank for leaks cowboyup Boat Restoration and Building 19 January 26th, 2005 05:23 PM
15' Aluminum boat leaks through rivots cobra 3.0 Boat Topics and Questions (not engine topics) 4 August 9th, 2003 05:32 PM
Aluminum boat leaks like hell bassboatfifty Boat Topics and Questions (not engine topics) 10 July 26th, 2003 05:58 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
