  #1
Old December 22nd, 2008, 07:27 AM
twr7cx twr7cx is offline
Send a message via MSN to twr7cx
Question Using straight hose as replacement tell-tale - 1993 Mercury 60HP 2 stroke 3 cylinder
The tell-tale on my 1993 Mercury 60HP 3 cylinder 2-stroke twin-carb outboard had a rip in it, so it was spraying water under the engine cover. I have removed it and put a longer hose on that pokes out through the hole. I have tested this with bunny ears and the water flows out no worries.
Is it fine to use like this? I am just concerned that the original tell tale only has such a small hole for a specific reason - e.g. to create back pressure in the cooling system?
  #2
Old December 24th, 2008, 12:29 PM
j_martin j_martin is offline
Default Re: Using straight hose as replacement tell-tale - 1993 Mercury 60HP 2 stroke 3 cylin
I think yer right. Most of the water should go into the mid to cool the exhaust. The little plastic thingie should pull off the old hose and insert in the end of the new one.
hope it helps
John
  #3
Old December 25th, 2008, 09:54 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
correct. the hose length does not matter,
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #4
Old September 19th, 2009, 06:25 AM
Quote:
My concern is not in relation to the hose length, I see no reason why that would effect anything. My concern is in relation to the diameter of the exit hole. If you look at the exit hole on the tell tales it's usually about 2mm ish, since I am just running straight hose and not the telltale, it has a larger exit hole (about 6mm ish) - this may cause the cooling system not to build up some pressure at the top which would encourage water to exit out the mid engine instead, or it may do nothing, I'm not sure.
  #5
Old September 20th, 2009, 09:48 AM
Moody Blue Moody Blue is offline
No worries about that setup you have. The telltale is located at the "end" of the cooling system, after it has passed thru the motor. It is only there to give an indication that water is circulating thru the motor. You are not robbing water from reaching the powerhead by increasing the hose outlet size.
  #6
Old September 25th, 2009, 10:23 AM
Quote:
Excellent, thank you.
  #7
Old September 26th, 2009, 05:10 PM
Mi duckdown Mi duckdown is offline
What you will have, IS, spiders, bees and such finding a good home. That is why merc put that little rubber thing on the cowl.
  #8
Old September 26th, 2009, 10:07 PM
Yep, usually have to clear the telltale a couple times a year. Mudwasps have a real knack for finding that little hole
  #9
Old November 9th, 2009, 11:31 PM
I ordered a replacement one at the local dealer last week, so it will go back on proper now.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Location of trim sensor on 1993 Mercury 60HP twr7cx Mercury & Mariner Outboards 1 April 7th, 2008 06:21 AM
1993 60hp mercury trim 0d260043 mytmouse Mercury & Mariner Outboards 5 February 27th, 2008 05:43 PM
60HP Mercury Carburated 4 Stroke vs. New EFI 60HP 4Stroke winstonmaggy Mercury & Mariner Outboards 2 March 22nd, 2004 10:45 PM
60HP Carburated 4 Stroke Mercury vs. New 60HP (EFI) Fuel Injected Models winstonmaggy Non-Repair Outboard Discussions 7 March 18th, 2004 06:36 AM
Mercury 150 poor idle after hose replacement bigbluebirdy Mercury & Mariner Outboards 2 July 10th, 2002 05:03 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
