Ships Ground on fiber glass boat.?????
w2much
My boat is fiberglass. My new Furuno says to run the ground cable on the back of the unit to the ships ground. What exactly is the ships ground?
ne7800
Re: Ships Ground on fiber glass boat.?????
if it's a io the engin bock should work
waterone1@aol.com
This is all about semantics. Depending on the size of your boat, this could be the negative buss, or a seperate ground buss, that is somewhere tied to the negative buss. In most cases, if you have other electronics in close proximity, just run it to the metal case or ground of that equipment.
dingbat
Don't bother hooking it up. My FCV585 runs fine without.
What Furuno did you get?
