Mercury 850 water pump/pressue
Guys, I have a 1975 merc 850. I started it up in the yard tonight and the water out the p-hole had a weak stream. I pulled the tube coming out of the block down to the p-hole, and there is good water flow out of the block, but if I put my finger over it, I can stop the flow easily. Fished a wire thru the tube and thru the p-hole, and feels clear. Blew into the tube out the p-hole, and the air goes thru, but there is pressue like it may be partially clogged. I will have to pull the tube and the p-hole fitting out to make sure they are clear.
My question is how much pressure should the water be under coming out of the block to the p-hole tube? Should I be able to stop it with my finger? I have been thinking of putting a water pressure gauge on the engine, would this tube be the best place, or is there a better place to put the sending unit for the gauge? The water pump/ impeller has less then 20 hours on it, first thing that was done after I bought the boat. Thanks
