I have a MD90b 03 model year the motor runs great but has some quirks I hope you can help me with. Iread your post about the 1000 cca battery and TPS resets.I installed new battery 1 yr ago not sure what cca it is but engine not starting very easy when cold but starts fine rest of the day. had battery tested and was told it was fine first thing I did was clean terminals could the battery be too small? It is a marine starting should I use combo battery? Next ,some times when I put it in gear the motor stalls and sounds and feels like the prop hit something. Took to dealer and he couldnt get it to do it and had no insight on what it could be. Next, the lower unit is cracking behind the propeller dealer said it was from corrosion between the lower unit housing and the ring with the 2 bolts top and bottom behind the prop. ASked him about having weld repair he said taking it apart would open a can of worms and it would be fine until it cracked into gear case grease leaked out then I could replace the whole lower unit is this good advice? Lastly, I have always De carbed my carborated engines yearly is this necessary with the clean burning tldi and if so how is it done? Thanks in advance
