  #1
Old December 18th, 2008, 12:52 AM
sschefer sschefer is offline
Default Repairing a Gash in a riveted aluminum hull
Hi folks, I've been overthinking this to the max and have called at least a dozen shops. Some say no problem just weld it but the most reputable shop say's the best thing to do is bang it out and patch it. Well, if banging it out and patching it is the best thing, I can do that myself. The advantage I have is that this gash is directly under a stringer and when it's bolted back in with 3/16 (#10) truss head stainless machine screws it will be tied together nicely. My plan is to grind out the rip to relieve the tension caused by the extrusion of the metal and then make an outer and inner patch from .050 aluminum sheet metal.
Before I put the patch on I need to add a filler. The filler will be tied from inside to outside via the ground out crack (1/8" after grinding) which will form a H type connection. Once the filler is hardened, I'll put a layer of Gluvit down on both sides and then put the patches on while the Gluvit is still wet. The inside patch will also have the stringer on top of it and the Machine screws will go through the outsite patch, the hull, the inside patch and the stringer with nylock nuts and washers on the stringer. The patches will get and exterior coat of gluvit feathered out about 4 inches all the way around and then the stringer will be laid in.
Does that sound like a sane idea?
Here's a couple of pic's of the gash. Yeah, I know, looks pretty nasty. The boat is an Insurance company total but mostly because of the amount of work it took to get it to a repairable state. Lot's of labor stripping this thing out and checking every nook and cranny. I was going to pay myself but I realized I was broke. Maybe I'll jump in the Jet and take a trip to Washington. Maybe I can get in on some of that bail out money. LOL..
Here's a relative perspective:
Let me know what ya'll think.
Thanks
Steve
  #2
Old December 18th, 2008, 04:51 AM
oops!'s Avatar
oops! oops! is offline
Default Re: Repairing a Gash in a riveted aluminum hull
one of the things about boat repair/building.....is....its really easy to get anal about things.
we all want to fix it the bes way we can....on fiberglass 12 foot boats we want to use epoxy with carbon fiber reinforced with kevelar.....then triple the floatation foam and add a deck that is a composite so it wont rot.....
and thats just the dingy we use to row to our 14 footers !
bang it out....weld it and splash some gluvit over....and go fishing
__________________
IN MEMORY OF Our friend SpinnerBait_Nut LESTER WRIGHT July 31, 1953 - Nov 26, 2008 RIP
  #3
Old December 18th, 2008, 05:10 AM
Nova II 260's Avatar
Nova II 260 Nova II 260 is offline
Quote:
Yep, my thoughts also. Lay some of this stuff in if it's too bad and still won't seal. Available at welding supply houses and fastenall
__________________
The Lead Dog has the best view.
  #4
Old December 18th, 2008, 06:53 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
yep, get it as straight as you can, weld it up. get someone who welds aluminum, as it is totally different process.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #5
Old December 18th, 2008, 09:03 AM
Bond-o's Avatar
Bond-o Bond-o is offline
Master Shipwright
Ayuh,.... I absolutely Agree....
__________________
Any Grease is Better,..... Than No Grease at All.......
NO PM's (Private Messages) regarding boat/engine problems. That is what these forums are for.
They will be Deleted
  #6
Old December 18th, 2008, 11:07 AM
Thank folks... Yep, I'm all for welding it as the best solution too! The patch is probably stronger in the long run but it's also ugly. Welded from the inside and filled with Lab Metal on the outside seems like the best solution to me also.
If you look closely you can see the riveted seams are a good 18" away from any welding. They will still need to be covered with wet rags because of aluminum's heat transfer characteristics. I don't want the mastic melting out of them. They will still get a coat of GluVit just to be on the safe side.
  #7
Old December 18th, 2008, 05:44 PM
Quote:
I weld aluminum (stick, spool and tig). I used to be good enough to weld vertical and overhead but I haven't done that in a while, (it hurts too much.).
I'm going to have a shop do this since I don't want to hear my friends tell me what crappy welder I am when it leaks. Its far better to have someone else to blame when your boat is sinking. LOL...
  #8
Old December 18th, 2008, 06:52 PM
Smile Re: Repairing a Gash in a riveted aluminum hull
Quote:
Originally Posted by sschefer View Post
.....The patch is probably stronger in the long run but it's also ugly........
Do you think the fish will see that patch and laugh at ya?
BTW, How did that happen?
__________________
  #9
Old December 19th, 2008, 12:33 AM
Well, I don't think the fish would mind too much. I would though and it's my boat not the fishes, (yet).
As for what happened.. Rumour has it that the guy was up at Clear Lake, Ca fishing Rattle Snake Island and stuck it on the rocks. Pretty easy to do even if you know that island. The rocks are mostly Volcanic and razor sharp. My brother bought it from the guy that put it on the rocks and paid the equivalant of the deductable on the guys insurance, (2500.00). It's a 91 MonArk Legend 1800 FS with a 91 Belgum made Mariner 100 (merc 115). Shortly after he bought it he realized he had too many other projects to do so I bought it from him for the same price. It's on a fairly new EZ Loader trailer with new rubber and bearings and the motor was completely gone through a year ago.
I stripped it down to tin only so I could check everything thoroughly. It's actually in pretty good shape but the craftsmanship was a bit lacking in several areas. I'm rebuilding it from the bare hull up and I'll take the time to do it right. The boat should last me long enough to save up for the North River that I really want.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
riveted aluminum boat seeping question phillyfisherman Boat Restoration and Building 4 July 21st, 2008 11:45 AM
Peddle boat hull gash - how to fix? joed Boat Topics and Questions (not engine topics) 9 July 18th, 2008 01:19 PM
Riveted aluminum Starcraft leaking bad FastOrange Boat Restoration and Building 7 July 4th, 2007 03:06 PM
aluminum riveted boat ? wayne h Boat Topics and Questions (not engine topics) 52 June 16th, 2005 01:24 PM
repair hole in riveted alum hull jpaulw Boat Restoration and Building 4 August 7th, 2002 07:44 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
