I have removed the old rotted plywood stringers, I cut off an inch from the top of the fiberglass and lifted them out leaving only the fiberglass walls standing. My question is if I can now fill the space where the old stringers used to be with some sort of foam (what kind of foam) or do I need to put in more plywood stringers. Also, if I replace the stringers with more plywood can I just fiberglass over the tops after I put them in or do I need to tear town all the fiberglass and start over?
