  #1
Old December 14th, 2008, 04:46 PM
jburn25's Avatar
jburn25 jburn25 is offline
Default Center Console Windshield and Grab Bar
Hi, I recently purchased a 17' aluminum flat boat with a center console. Boat is in great shape etc but the original owner never had a windshield on the console. I have found a few places that sell (cabelas) plexiglass boat windshields that should fit my 24" wide aluminum console just fine. However, I have not been able to find any one that sells the grab bars that you typically see going over the top of center console boat windshields.
I'm looking for a metal grab rail that will attach the the console on both sides and travel over the windshield.
If you know of anyone that sells these, please let me know. Worse case scenario, I guess I could try and get someone to fabricate one for me.
Thanks
  #2
Old December 14th, 2008, 05:02 PM
BigJ08 BigJ08 is offline
Location: A small town in Central FL I'm sure you've never heard of....
Default Re: Center Console Windshield and Grab Bar
The only time I have seen them sold is with a brand new console, so the bar is custom made for that console. I think you might be better off having a local shop or person fab one up for you. That way you don't have to try to make something fit, and you can have it just like you want it. Of course this option will cost a little more green. If you're really on a budget, you could just try waiting for one that would work to pop up on craigslist, I have only ever seen very few though. You have a few options but the dilemma is, as it always is for us boat owners, how much do you want to spend?
__________________
15.5 fiberglass CC, 1973 65 hp E'rude "the beast"
  #3
Old December 14th, 2008, 05:08 PM
arks's Avatar
arks arks is offline
Good luck. I had the same problem with my home-made console. I ended up fabricating my own lexan windshield and bending some 3/4" EMT conduit for a grab bar. Works OK but I'd prefer the bar to be a little bigger in diameter. No rust yet, but it's only been a year and I boat in brackish water.
__________________
"Winter Dream"
Silverton 34C
White/Green
Lowe 1446 BigJon
w/Johnson 25HP
  #4
Old December 14th, 2008, 05:35 PM
jburn25's Avatar
Arks, that grab bar looks great to me. My boat is a green flat bottom so I'll probably end up painting the grab bar black with some spray on bedliner so I'm not particular worried about rusting anyway. How did you attach it to the console? I'm guessing you had to make a 90 degree bend and then weld on a plate of some sort with bolt holes? Also, can you give me an estimate of how long of a piece of EMT you used? I'm going to try and find somewhere locally (shreveport, LA) to pick some up and just wondering approx how much material you used.
thanks!
  #5
Old December 14th, 2008, 05:39 PM
Bob_VT's Avatar
Bob_VT Bob_VT is offline
This is probably not going to be cheap but it will work.
Get some 1" or larger stainless steel tubing and have a muffler shop install the bends in it. The hydraulic machine will do a fine job. They can even expand or collase and end for making a slip fit.
__________________
"When you see yourself doing something badly and nobody’s bothering to tell you anymore, that’s a very bad place to be. Your critics are your ones telling you they still love you and care." Randy Pausch 1960-2008 The Last Lecture
SpinnerBait_Nut's Member Map Link Please add yourself http://www.frappr.com/iboats
  #6
Old December 14th, 2008, 05:57 PM
arks's Avatar
Quote:
I just drilled holes right thru the pipe and sides of the console. Used 1/4" bolts with washers and nuts. No big deal.
Well, if I was better at bending pipe I would've used less than 1-10' piece. I wasted probably 30 or 40 feet.
I finally figured out to make a pattern on plywood and bend it to match. DUH
__________________
"Winter Dream"
Silverton 34C
White/Green
Lowe 1446 BigJon
w/Johnson 25HP
  #7
Old December 14th, 2008, 07:23 PM
jburn25's Avatar
Ok, well I guess I'll give that EMT a try. If it doesn't seem like its going to be solid enough in 1" pipe I might try stainless, but I don't even know where to by a stainless pipe like that.
thanks
  #8
Old December 15th, 2008, 12:19 AM
DJ DJ is offline
Try these guys.
http://www.daytonasurplusmarine.com/
  #9
Old January 3rd, 2009, 12:32 AM
txmntman's Avatar
txmntman txmntman is offline
Thumbs up Re: Center Console Windshield and Grab Bar
ok, guys. Based on Arks work, I tried fabricating a grab rail today (actually 2). I used 3/4 inch EMT (10 ft for $7.00) and I bought a mechanical bender ($26.00). I drilled holes directly thought the tube and used small bolts to mount. Therefore, total cost for both rails was about $34!!!
The bending of the tubing was easy and came out looking very professional. I'll get pictures up soon. This was a problem that turned out to be a very easy and good looking solution.....Thanks ARK!!!!
  #10
Old January 3rd, 2009, 08:26 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
congrats.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #11
Old January 3rd, 2009, 11:38 AM
arks's Avatar
Your welcome.
It's always nice to help a fellow iboater.
__________________
"Winter Dream"
Silverton 34C
White/Green
Lowe 1446 BigJon
w/Johnson 25HP
  #12
Old January 20th, 2009, 04:54 PM
jburn25's Avatar
Wanted to update about the windshield and grab bar situation in case others are wondering about how to do it on their own boats.
I ended up buying a plexiglass windshield from cabelas and I'm really impressed with it. It's very sturdy and was the exact size I needed. From my research with other companies, I'd say the cabelas windshield is the best for the money. Only thing is if you are mounting it on aluminum make sure you have some sort of padding underneath it to absorb some vibrations so that the screws don't rattle loose and/or shear because I had that problem. My console isn't completely even so I ended up putting hydroturf on the whole surface which helps even out the load on the windshield when I tighten it down.
As far as the grab bar, I took Arks advice and went with 3/4" EMT and bought a mechanical bender. I did waste a couple poles trying to get the thing perfect, but I think the finished product came out pretty good. I put two 90 degree bends in the pole to get it up and around the windshield and experimented with bending the poles at the top so they would be parallel with the windshield but it didn't give enough room for your hands so I just left it straight. I also made some spacers out of marine plywood that keep the EMT off the side of the console so there's space to grab the bar and/or attach things. I used 1/4" stainless steel bolts through the bar, through the spacers, and into the aluminum console with large fender washers on the inside.
I'll try and post some pictures later once I get it all painted and everything in case anyone else is working on a similar project.
-Jordan
  #13
Old February 19th, 2009, 10:35 PM
jburn25's Avatar
Here's the pictures of the semi-final product in case anyone else is interested in doing this the same way. Made the spacers out of 3/4" plywood using a skil saw and cut the semi-circles for the rail to sit in with a drill. Very simple process. 1/4" stainless carriage bolts through the console. Rail is spray painted with bedliner in a can from auto zone.
  #14
Old February 20th, 2009, 07:20 AM
arks's Avatar
Nice job! I like the look with spacers- might have to retrofit my rig.
__________________
"Winter Dream"
Silverton 34C
White/Green
Lowe 1446 BigJon
w/Johnson 25HP
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Center Console windshield frame Scuda11 Boat Restoration and Building 3 June 7th, 2005 06:28 PM
center console windshield height jshoes52 Boat Restoration and Building 1 April 9th, 2005 07:11 AM
Mako center console windshield wreckdiver Boat Topics and Questions (not engine topics) 1 February 13th, 2002 06:02 PM
Mako center console windshield wreckdiver Mako Boats 1 February 13th, 2002 06:02 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
