i have a semi-v bottom alum. boat with a 20" transom, but with the vee i think it's more like 21". i know the cavitation plate is supossed to be below the boat bottom but how much height could i get away with. i steer in the front of the boat and it is fairly heavy engine that i'm mounting. i've seen boats with outboards mounted so high that the plate is above the bottom (not a tunnel). wouldn't this cause the prop to "suck air" at full plane?
