  #1
Old December 12th, 2008, 12:41 PM
sparky15 sparky15 is offline
Arrow 16ft Aluminum rivets
My project is a 16 foot starcraft I want to redo the floor. when I started taking the old carpet off I noticed that the wood floor went under the cabinets and casting deck and the cabinets are also riveted to the sides of the boat. the boat doesnsnt leak and the rivets that I would be drilling, wouldnt even be under water but Im not sure on the whole re rivet process expessially the rivets tap the shell of the boat.
I would like to do it right so I don't really want to cut around the cabinets and just replace that floor.
I have searched threads but cant seem to find anything for rivets
  #2
Old December 12th, 2008, 06:15 PM
Bond-o's Avatar
Bond-o Bond-o is offline
Master Shipwright
Default Re: 16ft Aluminum rivets
Ayuh,...
Google up "Closed End Pop Rivets"....
I've got an old Starcraft that would have been Scrap years ago without them....
__________________
Any Grease is Better,..... Than No Grease at All.......
NO PM's (Private Messages) regarding boat/engine problems. That is what these forums are for.
They will be Deleted
  #3
Old December 13th, 2008, 07:14 AM
5150abf's Avatar
5150abf 5150abf is offline
Redid my boat a couple years ago and had the same problem, I used SS bolts I had laying around and a dab of silicone, since they are above the water line they have worked out really well.
Being stainless they may cost as much as the rivets though, good luck.
__________________
GO IRISH!!!!
  #4
Old January 3rd, 2009, 01:08 AM
Cool Re: 16ft Aluminum rivets
How do you install these rivets, do you hold something against the rivet while you mushroom the other end of the rivet? I have used rivets with a rivet gun but it doesnt look like the same style rivet. remember im just a "cadet" when it comes to boats any help is appreciated!
  #5
Old January 3rd, 2009, 02:00 AM
Bard1's Avatar
Bard1 Bard1 is offline
Quote:
Originally Posted by sparky15 View Post
How do you install these rivets, do you hold something against the rivet while you mushroom the other end of the rivet? I have used rivets with a rivet gun but it doesn't look like the same style rivet. remember I'm just a "cadet" when it comes to boats any help is appreciated!
Yup, one guy on each side. They sell a set combo, if ya run alum. it's a good tool to have.Works like this, one guy on the inside and your the hammer man on the outside. either re'drill or set new rivets in a CLEAN hole, sharp gooodd Wacke or three and your in. best part about that, is if ya need too you can tighten up any lose rivets, do it same way but only one Wacke will do on that.
__________________
WE LOVE FUN STUFF!!!!!
  #6
Old January 3rd, 2009, 11:27 AM
Bob_VT's Avatar
Bob_VT Bob_VT is offline
Quote:
Originally Posted by Bond-o View Post
Ayuh,...
And google "Pop Rivet Tool"
The closed end pop rivets are a one person job and when you install the rivets for an extra measure of sealing ......place a dab of 3m 5200 on the rivet
__________________
"When you see yourself doing something badly and nobody’s bothering to tell you anymore, that’s a very bad place to be. Your critics are your ones telling you they still love you and care." Randy Pausch 1960-2008 The Last Lecture
SpinnerBait_Nut's Member Map Link Please add yourself http://www.frappr.com/iboats
  #7
Tacklewasher's Avatar
Tacklewasher Tacklewasher is offline
They do sell closed-end rivets that work with a standard rivet gun. They won't give quite the same look as the original rivets but are used in aircraft manufacturing and will do the job.
I have a bag of them for when I start work on my Starcraft (friggen snow)
  #8
Old January 3rd, 2009, 12:20 PM
Bond-o's Avatar
Master Shipwright
Ayuh,.... That's what I'm talking about...
They come in various Sizes,+ various Materials....
Order whatever Size you want, in Aluminum.....
Then just drill out the Bad rivet, insert a new 1, push,+ pump,...
Then you're Done...
__________________
  #9
Old January 3rd, 2009, 05:28 PM
cprince's Avatar
cprince cprince is offline
Quote:
Originally Posted by Tacklewasher View Post
... (friggen snow)
Oh yah... you guys finally got some snow! Welcome to Canada!!! :-)
Just think of it as thick rain!!
Not certain about Kelowna, but I have friends in Victoria that are not at all used to snow!
As for the rivets... what are the cost of those?
Are they sold by the pound or per rivet?
I will assume that they are aluminum?
Do they hold/last just as long as the OEM?
__________________
Look out Pike, Here I come!
My Current Restore Thread; http://forums.iboats.com/showthread.php?p=1852224#post1852224
My Old Restore Thread; http://tinyurl.com/3sv6gt
My Old restore blog; http://princescraft.blogspot.com/
  #10
Old January 5th, 2009, 01:55 AM
Thanks for all the replies guys I appreciate it!
now I can start drilling the old ones and get started on my project
I am assuming that the rivets used with the gun would be easier to install
or which one is recommended for easy installation and a good tight rivet or is it just personal preference?
  #11
Old January 5th, 2009, 03:44 AM
reelfishin reelfishin is offline
I went through the same deal with one of my boats here, the rivets were 3/16" in diameter and I couldn't find blind pop rivets in that diameter around here. I did luck out and wind up finding a 5 lb coffee can full of original style aluminum rivets and an aircraft riveter kit, which is basically just an air hammer with a bunch of specialized bits and an assortment of hand held backing blocks for the other guy to hold. The result is a factory rivet repair. I put a dab of 5200 on each rivet and wipe it clean after it's bucked in place. I replaced about 50 rivets on another boat which I eventually sold and it never leaked a drop. I had to remove and reinstall a cross bench seat and two ribs to weld up a tear. The end result looked like it was never touched. I water tested the boat for two days without a single leak.
The pop rivet gun though and some wide headed, long reach rivets will work well to hold your new floor in place, that's what the factory had used on mine.
As soon as the weather breaks, I have an 18 footer to do next. Luckily it's a two level floor and cuddy cabin layout, only the aft section is bad. If its put together the way I am guessing it is, it should be a pretty simple fix.
  #12
Old April 24th, 2009, 02:35 AM
Question Re: 16ft Aluminum rivets
I was looking to buy the rivets but when eyeballing things before purchasing the rivets I saw that the compartmentsthat get riveted to the side of the boat there is no swinging room to mushroom the other side of the rivet.
1}how would you install these if you only have 2 to 3 inches of space to try and mushroom the rivet tight? is there some specalty tool they use when installed in the factory?
I just can't picture it working,
the only reason i am leary about the pop gun style rivets is I know they seal and are easier but they dont have the same finish look to them, but I suppose you could smooth the hole in the center with J B wld or something?
Any input is appreciated
  #13
Old April 24th, 2009, 07:16 AM
halas's Avatar
halas halas is offline
"Ayuh,...
Google up "Closed End Pop Rivets"...."
Just do what Bond-0 suggested.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Aluminum Rivets rterrian Boat Topics and Questions (not engine topics) 7 April 24th, 2009 11:09 AM
Aluminum Rivets Leaking (again) alandchris Boat Restoration and Building 5 December 31st, 2007 09:08 PM
replacing floor aluminum rivets beertech44 Boat Restoration and Building 9 March 28th, 2005 06:50 PM
Aluminum boat rivets 87Aggie Boat Topics and Questions (not engine topics) 4 March 25th, 2005 07:45 AM
pop rivets in aluminum v hull wayne h Boat Topics and Questions (not engine topics) 4 May 27th, 2003 07:05 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
