  #1
Old December 10th, 2008, 07:33 PM
Jon Z Jon Z is offline
Default Pulling flywheel: '69 Evinrude 33
I'm having some trouble pulling the flywheel on my '69 Evinrude 33 hp. I plan on changing the points, coils, etc. Does anyone know the recommended method? I've tried a harmonic balancer puller, but the 3 threaded holes near the shaft are only 1/4 inch, therefore the bolts are way too wimpy to really crank on it. Can I use a 3 jaw puller on the outside diameter? I'm nervous about deforming the flywheel since it seems like pretty lightweight stuff.
Thanks for your input!
  #2
Old December 10th, 2008, 07:37 PM
Tim Frank Tim Frank is offline
Default Re: Pulling flywheel: '69 Evinrude 33
The harmonic balancer puller is the way to do it.
Pulling on the rim with a three-jaw is a fast way to need a new flywheel to replace the one you cracked.
  #3
Old December 10th, 2008, 08:20 PM
F_R F_R is offline
Don't even think about pulling on the outside rim. That will destroy they flywheel for sure.
Use the harmonic puller and Grade-8 bolts. Screw the bolts in 7/16", no more and no less. Then give it heck. It WILL come off if you pull hard enough and it does take a LOT of pull. You could lift a Humvee with those three Grade-8 bolts, so don't worry about them breaking. If the puller breaks, get a better puller.
When you put it back on, the flywheel and shaft tapers must be clean and dry and you MUST use a torque wrench to tighten the nut to 100-105 ft lbs. Again, failure to do so will destroy your motor.
  #4
Old December 10th, 2008, 08:25 PM
coolguy147's Avatar
coolguy147 coolguy147 is offline
those things r suckers to getting off( experience)
but make sure u keep the pull dead center to prevent it from slipping off and bending the bolts
__________________
http://photobucket.com/sgdteam
  #5
Old December 11th, 2008, 07:48 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
PULLING FLYWHEEL
you need a harmonic balancer puller, you need 3 - #8 harden bolts, that fit the 3 holes in your flywheel. standard hardware store bolts will strip out, causing more problems. loosen the flywheel nut, leaving it on so it protects the thread. thread the bolts in 7/16 of an inch. then tighten the puller, adjust so it has a straight pull. now tighten the puller, rap the center bolt with a hammer, then tighten some more. you may have to let it sit over nite, and repeat in the morning. this is a compression fitting, it will eventually POP!!. do not loose the woodruff key that goes in the groove of the flywheel and the crank shaft. then installing the flywheel, it has to be totally clean, no oil, woodruff key in place. then torque the nut to the specifications for your particular motor. if you do not do this, the woodruff key with shear, and you will be repeating these steps.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #6
Old December 11th, 2008, 10:36 AM
lucky7's Avatar
lucky7 lucky7 is offline
a squirt of pb blaster wouldnt hurt. best tool since the vise grip.
  #7
Old December 11th, 2008, 10:41 AM
yes, but the flywheel and crankshaft have to be perfectly clean, when reassembling.
__________________
FLORIDA GATORS
TEBOW Country
  #8
Old December 14th, 2008, 11:22 AM
Thanks for your input. Grade 8 bolts and a good crank... the flywheel came off with a BANG!
  #9
Old December 14th, 2008, 11:32 AM
yep!!!
__________________
FLORIDA GATORS
TEBOW Country
  #10
Old December 14th, 2008, 05:39 PM
After the second or third one that you pull, you won't jump at the "bang"....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Slow '69 Evinrude 33 Jon Z Johnson & Evinrude Outboards 11 December 14th, 2008 11:17 AM
40 hp '69 Evinrude flywheel jdcoombs Johnson & Evinrude Outboards 1 June 5th, 2008 05:30 PM
1969 evinrude 40 hp flywheel pulling jameswilson95 Johnson & Evinrude Outboards 7 August 11th, 2005 08:23 AM
Pulling flywheel on 1971 40HP evinrude outboard motor jgheck Johnson & Evinrude Outboards 1 June 24th, 2003 07:13 PM
Pulling flywheel on 1971 40HP evinrude outboard motor jgheck Johnson & Evinrude Outboards 0 June 24th, 2003 07:12 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
