  #1
Old December 10th, 2008, 02:04 PM
native son native son is offline
Default 15hp evinrude over heating
I rebuilt the water pump and replaced the thermastat on my 15hp evinrude but when it runs for about 10 min it gets hot and dies and then it wont start till it cools down it seems to push pleanty of water thru the pee hole but the water gets very hot what would cause this
  #2
Old December 10th, 2008, 02:25 PM
ezeke ezeke is offline
Default Re: 15hp evinrude over heating
Generally, the thermostat is not opening.
The water flow is through the engine to the thermostat or bypassing the engine, which is why tell-tales indicate that the pump is working but cannot tell you if the water is going through the cooling passages of the engine.
You might also have debris in the circuit.
  #3
Old December 10th, 2008, 02:37 PM
coolguy147's Avatar
coolguy147 coolguy147 is offline
what year is it?
y wouldnt the t stat work if u justed replaced it mmm.. well on my evinrude the t stat is right at the top of the head and i would just take a hose at low pressure and try to blow it out idk lol?
__________________
http://photobucket.com/sgdteam
  #4
Old December 10th, 2008, 08:18 PM
Rick. Rick. is offline
That's killing your engine. I would suggest pulling the stat and leg and direct connecting a garden hose to the water tube and flushing the engine through the thermostat hole. You must have a blockage if your getting good flow to the pee hole. While the stat is out I would also suggest placing it in a cup of boiled water and visually checking to make sure it opens up. Just because it's new doesn't mean it works although my guess is that it will work properly. Beyond that maybe the water tube grommet isn't lined up at the pump but then you wouldn't be getting a good stream at the pee hole. Best of luck. Rick.
  #5
Old December 10th, 2008, 09:23 PM
battler battler is offline
Some 15hp have a grommet on top of water tube that turns itself insideout and restricts water flow. Unfortunatly powerhead has to come off to change it.
  #6
Old December 11th, 2008, 10:48 AM
mikesea mikesea is offline
if your impeller and thermo are ok,the culprit is probably a collapsed grommet that is located at top of water tube below the powerhead,it is a very common problem on the 9.9 and 15,powerhead needs to be removed to expose the grommet
  #7
Old December 11th, 2008, 01:27 PM
nightstalker nightstalker is offline
Quote:
What he said.
Nightstalker
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
evinrude v4 110 over heating skidaddy65 Johnson & Evinrude Outboards 6 September 9th, 2004 07:57 PM
1988 15hp Evinrude over heating hdroad Johnson & Evinrude Outboards 10 September 8th, 2004 10:19 AM
1977 15hp evinrude = 15hp evinrude fastwin JohnZ Johnson & Evinrude Outboards 2 October 2nd, 2003 04:03 AM
60 evinrude over heating alarm alexcalvin Johnson & Evinrude Outboards 2 August 3rd, 2003 07:27 PM
1983, V4 90 HP evinrude over heating jgrover92064 Johnson & Evinrude Outboards 1 July 8th, 2002 05:58 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
