  #1
Old December 9th, 2008, 12:47 AM
simonjensen simonjensen is offline
Default 2 stroke 70 Yamaha dramas - Problem Solved :)
Hi have to say this site really seems invaluable. I hate to go over ground thats already been covered but bear with me. I've got a 70 hp Yamaha 2-stroke about a 93 model i think. Engine starts fine and runs perfectly, problem is when i back off the throttle then go to accelerate again the engine will only run at an idle speed while in gear. In neutral the engine can be revved as normal but with the load of the boat on it, it wont respond. If i let the engine cool for a half hour or so it returns to normal operation until i back off the throttle again. I've installed new water/fuel seperator, fuel lines and plugs but problem persists. There is one segment of line i didnt replace and probably should, but i cant understand why it would run perfectly until i return it to idle. i should point out too that when it does play up and run at minimum revs any further attempt at acceleration will cut the engine, yet it will start again no worries. It may just be coincidence but the problem started when i had to slow down for a 3ft wake of a yuppy vessel. Ironically it was a big Riviera and i quit working for them the previous week..thats karma i guess. Any thoughts appreciated thanks
Simon
  #2
Old December 9th, 2008, 11:35 AM
cousinabe's Avatar
cousinabe cousinabe is offline
Default Re: 2 stroke 70 Yamaha dramas
when was the last time you changed the fuel pump?
  #3
Old December 9th, 2008, 05:51 PM
I've never replaced the fuel pump do u think that may be the problem? I just dont know why it will run perfectly and then play up. A fuel pump is a good call, if it was my car thats probably the first thing i'd look at.
  #4
Old December 9th, 2008, 07:04 PM
pine island fred pine island fred is offline
Master Chief Petty Officer
Long shot here but takes no effort to try. Leave the gas cap loose. If you have one of the newer sealed tanks like I do, the venting is done thru the cap. FRED
  #5
Old December 10th, 2008, 04:32 AM
Dunaruna's Avatar
Dunaruna Dunaruna is offline
Send a message via Skype™ to Dunaruna
A model number would help.
Next time it happens, try pumping the bulb. If it accelerates without dieing, fuel pump problem.
I had similar symptoms to what you are describing, Two of my coils would crap out when warm. In the genuine manual there are very easy test procedures for coils (and everything else). i would suggest performing those test procedures both cold and hot (a hair dryer is perfect for warming up electronics).
__________________
Watch this space......................
  #6
Old December 10th, 2008, 08:43 AM
Thanks for your help guys, i'll put it through its paces and try and isolate the problem, the engine is a 70BETO. A few other thoughts are really good to realise how many things a motor relies on to function properly. Sometimes its hard to differentiate between electrical and fuel problems. I've got a Valiant Charger, an Aussie Chrysler and been having engine problems....after replacing heaps of bits to do with fuel and electrics i finally isolated the problem (with the help of a few friends)...the oil pump, unfortunately that means pulling out the old hemi. i wish i'd been a mechanic..
  #7
Old December 10th, 2008, 09:25 AM
Dunaruna's Avatar
Where are you located (in aus)?
__________________
  #8
Old December 10th, 2008, 09:43 AM
I'm on the Gold Coast mate, got a nice spot, boat ramp's only a stones throw away
  #9
Old December 11th, 2008, 04:32 AM
Dunaruna's Avatar
Bottom right hand corner of your id plate is a solitary letter, that letter is the year code, what is that letter?
Do you have an analogue tach with the 3 oil warning lights?
__________________
  #10
Old December 11th, 2008, 08:52 AM
I have the letter "A". i think its about a 93 model. When i bought it i thought it was a later model it's in pretty good nic, been well looked after. I've had it a couple of years now and until this current problem its been excellent. I've got the analogue tacho with the three lights i havent used it for a few weeks but i'm pretty sure those lights were not lighting up while i've had troubles. They did work until recently. I put it down to a loose wire or something but kept an eye on the oil level, perhaps i should have put 2 and 2 together. Thanks for your interest too mate
  #11
Old January 8th, 2009, 09:34 AM
Smile Re: 2 stroke 70 Yamaha dramas
Thanks guys for your assistance, i pulled the 3 carbies off, dismantled them and gave them a thorough clean and blow out. Gaskets were good and reusable. I found quite a bit of gunk and crusty bits particularly in the lower carb. I drained the oil and the fuel, cleaned the fuel pump and somehow managed to put everything back together without any dramas. Took it for a test drive tonight and what do u know....she runs absolutely perfect. Sounds nice and throaty, just runs like a dream..better than ever. Just goes to show even if u only have half a clue what youre doing..there's only one way to learn and thats pull out the tools and have a go...might even save u a few hundred bucks. Cheers
  #12
Old January 8th, 2009, 01:43 PM
Capt. Cooper Capt. Cooper is offline
Dunaruna-
I just bought a Yamaha 70hp outboard, early to mid '90's model, but I do not know the actual year. Am I able to tell with the solitary letter / year code? Where can I find the codes to determine the year. I do not have the motor at the moment to read the ID plate and the letter.
Mahalo!
  #13
Old January 8th, 2009, 05:59 PM
ianyoung77 ianyoung77 is offline
The question now is where did the gunk come from? Have you emptied your tank and cleaned it? Also your fuel pump may have some in it as well which may end up in the carbie.
  #14
Old January 8th, 2009, 06:45 PM
Dunaruna's Avatar
Ian, this is the letter in question (bottom right hand corner).
Capt. Cooper, you have a PM.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
i have an old evinrude and i wana know if i can swap the foot on a old johnson asha Johnson & Evinrude Outboards 4 May 28th, 2008 07:18 AM
How do I get the sludge out of my old old 2-cycle oil tanks? achilles555 Mercury & Mariner Outboards 7 April 7th, 2008 03:42 PM
Old Singers remaking their old songs to match their age. jinx Dockside Chat 5 July 22nd, 2005 07:54 AM
New, Old...boat help removing old stickers... G. Arruda Boat Topics and Questions (not engine topics) 7 July 22nd, 2004 11:28 AM
Is 4 month old gas to old to run in a new 4 stroke? blueboat1 Johnson & Evinrude Outboards 2 July 30th, 2003 02:53 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
