  #1
Old December 8th, 2008, 06:45 PM
loosenut loosenut is offline
Default Mercury 9.9 hp ,not pumping water
I traded for a mercury 9.9 hp to go on my old flat bottom .I headed down the river and it quit running about 200 yards out.I got to looking the motor over ,and found dirt in the P hole.I guess it was the work of a dirt dobber.I trolled back to the launch and started it back up long enough to shoot it back on the trailer. I unstoped the P hole and ran it a few seconds in a 55 gal. drum of water and it still wont pump . I blew the line out and still no water came out.Im guessing the impeller is bad ,but I need some imformation on where to start and how to get to the impeller .I also need to know witch impeller to buy. 9.9 Mercury S/N OB172064.
Thanks,, Loosenut
  #2
Old December 8th, 2008, 07:40 PM
Laddies Laddies is offline
Default Re: Mercury 9.9 hp ,not pumping water
Start the job with a manual, it will save you time and money.
  #3
Old December 9th, 2008, 01:14 PM
Default how do I unhook gear shift linkage on 9.9 merc.
can someone tell me the best way to unhook shifter linkage when removing lower unit on 9.9 merc.
  #4
Old December 9th, 2008, 01:25 PM
Look under the port side of the carb, there will be a screw and some have a latch pin.
  #5
Old December 9th, 2008, 01:43 PM
Default thanks.. I got the lower unit off but .
the impeller looks new ,but it looks to big for its housing .looks like someone folded the rubber blades back to get it in the housing .there is no key or anything holding the impeller in place on the shaft and I dont see how the impeller can turn ,especialy with the blades mashed against the housing. (WRONG IMPELLER MABEY?)
  #6
Old December 9th, 2008, 03:35 PM
Whoopbass Whoopbass is offline
Impellers fit tight so i'm sure that is the right one. Since it was pumping water before you probably lost the key when you removed it. You need to find the old key or buy another one.
Since you have the lower unit off stick a garden hose with a jet nozzle in the water pick up tube and see if you can get water to shoot out the pee hole.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury outboard not pumping water mwrBoat Mercury & Mariner Outboards 3 June 23rd, 2009 01:11 AM
9.9 mercury 4 sroke not pumping water dpfeiffer1 Mercury & Mariner Outboards 1 September 26th, 2008 12:16 PM
Mercury 9.8 not pumping water boat1031 Mercury & Mariner Outboards 4 August 6th, 2008 11:28 AM
7.5 mercury (no water pumping) 308user Mercury & Mariner Outboards 7 April 23rd, 2007 11:25 AM
water not pumping mercury burtinski Mercury & Mariner Outboards 1 April 15th, 2003 05:34 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
