  #1
Old December 8th, 2008, 05:46 AM
rbthntr64's Avatar
rbthntr64 rbthntr64 is offline
Question Any hope restoring a Evinrude Yachtwin 3532A?
I picked this up from the same guy I got the fishmaster boat from. He did not take very good care of this little guy and the pistons are froze solid in the cylinders. Do you guys think it is possible to restore this little guy? Is there rebuild parts available? I am not sure I will be able to get the pistons out with damaging something. I have it completely disassembled down to the cylinders. The ignition parts are bad also.
  #2
Old December 8th, 2008, 08:59 AM
F_R F_R is offline
Default Re: Any hope restoring a Evinrude Yachtwin 3532A?
Anything is possible if you are willing to spend the time and money. But does it make sense? Perhaps that money could be better spent on a good running motor.
  #3
Old December 8th, 2008, 10:03 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
it will cost you far more than the motor is worth. sell the lower, and use the $ toward a better candidate.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #4
Old December 8th, 2008, 11:02 AM
mthieme's Avatar
mthieme mthieme is offline
As much as I like old stuff, I agree with TD unless you're looking for a project.
__________________
Nothing is so broken that Government can't make it worse.
  #5
Old December 8th, 2008, 06:31 PM
freddyray21 freddyray21 is offline
1965 3hp there are a bunch of power heads out there to be had. I would not put the money in it.
  #6
Old December 8th, 2008, 06:36 PM
JB's Avatar
JB JB is offline
If it was a '57 Bel Air with FI and a frozen engine, what would you do?
__________________
RED SKY at night. . .
JB
  #7
Old December 8th, 2008, 07:06 PM
Quote:
little different story
  #8
Old December 8th, 2008, 09:37 PM
JB's Avatar
JB JB is offline
A classic is a classic. That is a wonderful little engine.
__________________
JB
  #9
Old December 9th, 2008, 02:08 AM
rbthntr64's Avatar
I would love to restore it. It has seen better days and some of the parts are missing. The tiller arm is gone and the tank is dented up pretty badly. THe ignition parts fell apart when I removed the flywheel. If I could secure the parts, I would rebuild her. Are the decals still available?
  #10
Old December 9th, 2008, 04:13 AM
rbthntr64's Avatar
Smile Re: Any hope restoring a Evinrude Yachtwin 3532A?
OK, Being a jet engine mechanic by trade, I am not going to give up without a galant effort. I got the pistons out using my Cummins tool press. Once they started to move, they came out without event. The cylinders look ok at the top, but the bottoms are pretty bad. I took a couple of so-so pics to see what you guys think. Going to US Boatworks in KCK in the morning to talk with mike. 27 years of experience is worth an opinion on rather or not this little guy is worthy of resurection or a part out. Any of you guys have other sources for hard to find parts? I think the cylinders may require boring to get through the pitting from the rust, so over sized pistons may be the order of the day.
THanks
  #11
Old December 10th, 2008, 01:31 AM
rbthntr64's Avatar
Quote:
Can you point me in the direction?
  #12
Old December 10th, 2008, 06:10 PM
www.aomci.org and post an ad on the classifieds.
  #13
Old December 10th, 2008, 06:23 PM
G DANE G DANE is offline
I would try a light hone to start with, and go from there.
  #14
Old December 11th, 2008, 01:41 AM
rbthntr64's Avatar
Talking Re: Any hope restoring a Evinrude Yachtwin 3532A?
Quote:
Got the hone, and the seemingly gold value parts. What oil should I use when honing? Still need the ignition parts and have to make the reed plate gaskets unless someone know where I might find some. Also need a tiller arm and associated harware. Referencing "light hone" could you elaborate? I am new to these processes, but I am not skeerd
Thanks all!
  #15
Old December 11th, 2008, 02:26 AM
ooldschooll ooldschooll is offline
Napa auto has alot of the parts for the 3 hp. Im repairing my 3 hp johnson 1954. Redone in good working order its worth around 200 bucks give or take 25. thats good ignition new impeller and water proof lower. restored ,new or like new no dents good paint 300 - 350.if napa dont try here http://www.vintageoutboard.com good luck
__________________
Randy
  #16
Old December 11th, 2008, 02:38 AM
I use ordinary 30 engine oil, when I hone. Be sure your tool is for cylinderhoning, not the bruches. By light, I only mean a couple of seconds, and then clean it up, and observe the results. You can actually hone so long it will get out of spec. They are pretty forgiving, though. Now and then things turn up on ebay. Sometimes if you contact the seller, they have other items for a motor they have taken apart, but only lists what they think is sellable. Good luck, I wish it was me, love those oldies. Pistons look great, thus the reason for the advise for honing .
  #17
Old December 16th, 2008, 02:23 AM
rbthntr64's Avatar
Question Re: Any hope restoring a Evinrude Yachtwin 3532A?
Anyone have a recomended shop in Missouri near Sedalia or Truman Lake that could do the hone work for me?
THanks
__________________
Freedom is not free. Some will perish to preserve it for the many.
  #18
Old December 17th, 2008, 01:35 PM
rbthntr64's Avatar
OK got it honed. Wasn't very difficult. Now to my next question. When I pressed the pistons out, I think I may have distorted the end caps a bit. When I tighten them down, they are very tight on the crank. The book calls for a cap with needle bearings, but the ones in this engine are solid aluminum.
They do rotate with a little force, but do you think this will be okay once it is running and warm? My thinking is expanding aluminum will loosen up. What say the experts?
Thanks
__________________
  #19
Old December 17th, 2008, 05:33 PM
jonesg jonesg is offline
I think the rods, if tight, will bind and gall up on the crank. Then snap.
If you can measure to see if they've gone out of round, a boring cutter in a vertical mill should bring them back into round.
Small engines I've worked on had brass bushings in the lower end with a small hole for lube. It helped to run a reamer through them to prevent galling. If they've gone out of spec a machine shop should be able to bush the lower end of the rods....if parts are not available.
  #20
Old December 19th, 2008, 01:33 PM
samo_ott's Avatar
samo_ott samo_ott is offline
They should not be tight. A lot of wear can happen when first starting before lube gets in there.
Also check out this thread:
http://forums.iboats.com/showthread.php?t=287440
__________________
Steve.
  #21
Old December 19th, 2008, 02:52 PM
Did you drive the pistons out with a hammer on the rod caps ?? If you did, you probably deformed the rod caps, since they are aluminium and not cast iron. If thats the case, I would try to place them in a bench grip and CAREFULLY pres them in on the sides, and try them on the cranck a couple of times. Were the rodbolts tight when you did it ? If they were the entire hole would be oval, then, both caps and rods. Be aware of risk of metal tiredness !! Be carefull.
  #22
Old December 20th, 2008, 02:15 PM
rbthntr64's Avatar
Rod caps are AFU. So now what do I do? I noticed one of them has a crack in it. ANy chance of getting the caps?
__________________
  #23
Old December 20th, 2008, 03:51 PM
tx1961whaler tx1961whaler is offline
Honestly, at this point it's cheaper to get a new power head off of ebay or some other source. They show up regularly. I brought back a 3 recently (used in saltwater) that had been frozen and sitting for a decade by soaking everything inside and out in penetrant for a week, slowly rocking the flywheel occassionally and respraying everything until it came loose and would rotate. Then everything was soaked again in motor oil and slowly worked through until it was loose. This whole process took about 3 weeks, just to get it to a point where I could run a compression check to see if it was worth going any further. The only bolts that I couldn't get free were the big transom mounting bolts, so I got a whole new (old) bracket and bolts off of ebay for 5 bucks. I only did this because the motor had sentimental value to me, and I knew it was running perfectly before being parked. The first tank of gas during and after a decarb was run at a 16:1 gas/oil ratio. I certainly wouldn't try this process with a precision bearing motor, but the old 3's are a bit more forgiving.
  #24
Old December 20th, 2008, 04:01 PM
I would go looking for a new pair of rods, should not be that hard to find, shop a little around, or look for another powerhead eventually with some kind of fault, one that has overheated or so.
  #25
Old December 20th, 2008, 06:07 PM
Here. They are on there all of the time (search for Lightwin or Ducktwin or Yachtwin):
http://cgi.ebay.com/Vintage-EVINRUDE-Boat-Motor-Engine-Assembly-LIGHTWIN-3_W0QQitemZ320325101480QQcmdZViewItemQQptZLH_Defau ltDomain_0?hash=item320325101480&_trksid=p3286.c0. m14&_trkparms=72%3A1205|66%3A2|65%3A12|39%3A1|240% 3A1318|301%3A1|293%3A1|294%3A50
http://cgi.ebay.com/ebaymotors/Evinr...ssoriesQ5fGear
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude Yachtwin Model # 3532A h2owell Johnson & Evinrude Outboards 3 July 17th, 2009 09:11 PM
1965 evinrude yatchtwin model 3532A lwood@nwi.net Johnson & Evinrude Outboards 5 July 12th, 2008 08:26 PM
evinrude yachtwin donnagirl40oz Johnson & Evinrude Outboards 3 July 12th, 2007 05:39 PM
Evinrude Yachtwin Reel Appeal Johnson & Evinrude Outboards 2 May 17th, 2003 09:17 PM
Evinrude Yachtwin h2owell Johnson & Evinrude Outboards 6 June 16th, 2001 09:50 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
