  #1
Old December 6th, 2008, 06:38 PM
jakestevens jakestevens is offline
Default mercury 65hp 3cyl water leak
I have a few things going on with this mercury 65hp 3cyl, but one thing I noticed today could be the cause of most of my problems. While I could only get it to run with the fast idle lever engaged halfway, I walked around the outboard inspecting things. I noticed water blowing from the exhaust plate(I believe that's what it is called). I marked the area in the pic attached. My questions are: (1)Does the powerhead have to come off to replace this gasket? (2)If not, where would you start the tear down?
(3)What gasket kit will I have to order perform the repair?
Thanks a lot for all the info thus far!! I consider this forum a very important tool in my repairs.
  #2
Old December 6th, 2008, 07:03 PM
mthieme's Avatar
mthieme mthieme is offline
Default Re: mercury 65hp 3cyl water leak
Yup, unless I'm mistake the studs/bolts right under that are for the power head.
Fortunately you can get just the powerhead base gasket (housing) gasket.
Available right here at the iBoats superstore!!!
A better man that me is going to have get you the part number though.
They run less than $10.
__________________
Nothing is so broken that Government can't make it worse.
  #3
Old December 6th, 2008, 07:11 PM
emckelvy emckelvy is offline
The gap indicated is the juncture between the powerhead and the exhaust adapter. You'll have to pull the powerhead to replace the gasket.
Check out the below site, pull up diagrams for your motor by Ser # and you'll see a parts breakdown for the gasket you need to order.
Check the parts category "shift linkage and exhaust plate".
http://www.mercruiserparts.com/Selec...asp?class_id=2
Your motor doesn't look too salty so it should be an easy teardown.
HTH................ed
  #4
Old December 7th, 2008, 10:48 AM
Thanks emckelvy for the link. My outboard is a 1975 650 3cyl. and the serial number range is 3547987 THRU 4382056. I saw the pic of the gasket on the "shift linkage and exhaust plate" diagram. It looks like the gasket is no longer available. Would there be another source for this part?
  #5
Old December 7th, 2008, 11:12 AM
I had found a better picture of the diagram and I was reading the wrong number. So looks like it is available so thats great. I have lots of fuel leaking around the carbs so I was going to rebuild those as well. Is there any other associated gaskets I will need to replace or should replace while I'm pulling the powerhead?
  #6
mthieme's Avatar
Sierra and Mallory have the whole powerhead gasket kits available (worst case). PN 18-4352 and 9-64208 respectively. The whole kit runs about $50.
These are easy to find....iBoats has 'em.
__________________
  #7
Old December 7th, 2008, 11:23 AM
thanks folks.. I think I'll jump into it since I know I can get the parts, then order what i need.. I'll let you know what happens.
  #8
Old December 7th, 2008, 11:43 AM
mthieme's Avatar
Tip - check the lower motor mounts by rocking the motor back and forth. Watch for play at the lower mounts while doing this. If you have any play, this would be the time to replace them. Considering the age of your motor and you're popping the powerhead anyway (required to replace lower mounts).....food for thought...
Also, you may have to order through a Merc dealer if needed.
__________________
  #9
Old December 8th, 2008, 10:58 AM
noahnsteph noahnsteph is offline
Send a message via MSN to noahnsteph Send a message via Yahoo to noahnsteph
If you're going to pull the carbs you might as well rebuid them. I have a 1973 Mercury 650 3 cyl and I found the complete rebuild kits for the carbs right here on iboats for $15.99 for each carb. The kits have every gasket, O-ring, spring and jets you will need to completely rebuild the carbs. I was very impressed when they arrived. Compared to what I'm finding for supposed carb kits for my mototcycle the kits for the 650 are a smoking deal.
  #10
Old December 8th, 2008, 06:11 PM
mthieme's Avatar
It's hard to disagree, but the last 65 was made in 1976. It probably wouldn't be hard to find work on that puppy.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
peehole 72 johnson 3cyl 65hp dannyblackpool Johnson & Evinrude Outboards 7 October 23rd, 2008 10:30 PM
1975 3cyl 65hp stalls after brief high speed Helly Mercury & Mariner Outboards 3 August 4th, 2008 09:20 PM
No spark - 65hp, 3cyl Evinrude Woodbark Johnson & Evinrude Outboards 1 August 3rd, 2005 07:48 AM
Merc 65hp 3cyl 650 werdna Mercury & Mariner Outboards 0 September 10th, 2003 05:44 AM
Mercury Thunderbolt 650cc 65hp 1970 has a water leak ;( y2jericho Mercury & Mariner Outboards 2 April 2nd, 2003 04:37 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
