82 Viking OMC
- Sep 29, 2008
- 3
Greetings
I own a 1982 Viking Cuddy with a V6/omc 800 powertrain.
Last time it ran i was pulling a kneeboarder and was turning to retitieve after they dumped. I slowed before turning and tried to turn wide.At that point i had a major malfuntion. Some how my motor mount and drive mounts both tore ouf of the deck causing about a 10 degree rotation and a 3.5 inch lift on one side.
Used my handy OMC attitude adjuster to get the engine back in place but no longer have any engagement into forward or reverse.Checked the plate on engine (not sure what its called) to confirm it was moving,it was. I have no noise or prop rotation and i think the ball gear is turning.(it grinds when i raise the drive. I know the ball gears need replacement but does anyone know how i should proceed to troubleshoot the "shift"issue? And also any advice on how to remount the motor/drive mounts?
