  #1
Old December 4th, 2008, 07:41 PM
army_guy army_guy is offline
Question Help With Aluminum Rebuild
I am rebuilding an 1968 14ft Aluminum Duracraft. This boat has three bench seats. What I want to do is remove the middle bench and put in a carpeted floor. Both because of the design and because I want to bang out a dent that is confined behind the bench.
My question is about rivets. I would need to replace approx 20 rivets. I have read how to do it but I am afraid of the leaks it may cause. I would like to hear any suggestions or tips on weather I should remove the bench or not. And if I do remove it... how hard is it to replace them and keep my boat leak free.
I'm new to iboats... so go easy on me if this has been discussed already.
  #2
Old December 4th, 2008, 08:20 PM
arks's Avatar
arks arks is offline
Default Re: Help With Aluminum Rebuild
First, welcome to iboats!
I would not recommend taking out the seat. The framework is most likely structural to the hull and if removed, the hull sides will weaken considerably. Maybe you could try to contact someone at Duracraft and see if they think it would be OK (my guess is NO).
As far as the dent, try a suction cup puller. They work pretty well on light gauge stuff.
__________________
"Winter Dream"
Silverton 34C
White/Green
Lowe 1446 BigJon
w/Johnson 25HP
  #3
Old December 4th, 2008, 09:04 PM
Bob_VT's Avatar
Bob_VT Bob_VT is online now
I am a former Army (retired in 93 from FLW, MO) can you get anything in to feel the dent behind the seat?
How big of a dent? You might ask around and see if there is an automotive Paintless Dent Removal person (they have the tools).
Welcome to iboats! Are you stationed in MO?
__________________
"When you see yourself doing something badly and nobody’s bothering to tell you anymore, that’s a very bad place to be. Your critics are your ones telling you they still love you and care." Randy Pausch 1960-2008 The Last Lecture
SpinnerBait_Nut's Member Map Link Please add yourself http://www.frappr.com/iboats
  #4
Old December 4th, 2008, 09:18 PM
Calhere's Avatar
Calhere Calhere is offline
Send a message via AIM to Calhere
With the dents you can use a ball ping hammer hold a piece of wood or something flat to the other side and tap out the dents.
On the seats im confused, are you wanting to permanently remove them or replace them with new wood? If so I would use a piece of hard wood you can pick up at home depot lamb pine works great just coat it with primer or a marine grade varnish.
As far as the rivets go ahead and replace them then you can use gulvit or something of that nature that will keep it from leaking.
__________________
Here I go again...
  #5
Old December 4th, 2008, 09:54 PM
I am planning on permanently removing the bench. I will mostly be fishing alone or with my wife. I wanted the bench gone so I don't trip on it moving to the front of the boat. As well as hold important items like the beer cooler. I am putting in a flat carpeted floor between the two other benches.
I don't think that bench has much structural value. I have seen them removed on similar Aluminum V-bottoms.
I will post pictures of the dent tomorrow. I banged out what I could already. I can't reach the rest without removing the seat.
I was mostly concerned on being able to replace the rivets.
Thanks for the warm greetings... and I just finished school in MO and am waiting for my orders to go????
  #6
Old December 4th, 2008, 10:13 PM
Calhere's Avatar
Have fun Man I was in I got a Medical Ret in 2006 after taking shrapnel in iraq
__________________
Here I go again...
  #7
Old December 4th, 2008, 11:13 PM
Bond-o's Avatar
Bond-o Bond-o is offline
Master Shipwright
Ayuh,... Google up Closed End Pop Rivets.......
__________________
Any Grease is Better,..... Than No Grease at All.......
NO PM's (Private Messages) regarding boat/engine problems. That is what these forums are for.
They will be Deleted
  #8
Old June 11th, 2009, 12:11 AM
jerry1865 jerry1865 is offline
rivets, no problem. 2 ways to go. factory type(solid core) can be put it with a bucking bar and an air hammer with a dished punch.
i personally prefer 3/16 or 1/4 inch closed end pop rivets that you put in with an air riveter.( pease do not try this without the air riveter)
as to the bench removal. no big trouble, just be sure to put in 2 pieces of angle aluminum to act as ribs. and you will have her whipped.
(its pretty easy to form the aluminum to act as ribs)
  #9
Old June 11th, 2009, 08:22 AM
Bob_VT's Avatar
Hmmmmm This project was completed in Jan 09 ........ about 6 months ago.
Thanks for posting but check the dates!!
__________________
Closed Thread
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
The Beginning - 1964 Starcraft 18.5ft Aluminum Rebuild tcooke Boat Restoration and Building 14 June 27th, 2008 08:18 PM
18' Bluefin Aluminum Rebuild Restoration imported_Cpt_Quint Boat Restoration and Building 16 December 21st, 2006 11:25 PM
The rebuild of an aluminum runabout swimmin' for shore Boat Restoration and Building 27 November 7th, 2005 06:55 PM
Aluminum Boat Transom Rebuild cclaeys Boat Restoration and Building 4 August 17th, 2004 08:19 PM
Small chunk of aluminum missing around water jacket- will this effect my rebuild Sal G Johnson & Evinrude Outboards 3 September 27th, 2003 05:08 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
