I am not able to get the motor to shift. I had it to a "marine" mechanic to get some work done. He did a carb kit and replaced the impeller. The first time I took it out, it wouuld not start, so I took it to the boat ramp and with the help of a few friends, got it to start, then, while in neutral, it prop would turn as if in forward. We took to boat out of the water and pulled the breather off the carb, we noticed that a linkage was not re-installed, so we do that. Now it will still not shift. The handle moves but does seem like the shift rod is connected to the shaft. Does the whole lower end have to come off to check if the yoke is connected, or can I do it with just the prop off?
Paul
Paul
