  #1
Old December 2nd, 2008, 09:17 AM
Tbagley Tbagley is offline
Default Loss of RPM's at WOT, Evinrude 90hp 1997
Great site, I've searched for an explaination but haven't been able to locate a potential fix. It's 1997, 90 hp 60degree engine. She seems to start and idle just fine, at some point in the past, which may have been after a carb job...I just don't recall... I would accelerate and get up to about 5000rpms then the engine by itself would settle back to 4500, without moving the throttle back. Possibly related, occasionally upon acceleration before the boat hits plane the engine would seem to hit a sweet spot for a moment and really accelerate the way I recall it use to a year or so ago, an then it would back off that. This motor use to easily hit the 5500 mark and these days 4500rpm is the norm. I had found potentially a couple of minor fuel/air leaks and have repaired/replaced what ever I found. I at first thought it may be have a fuel starvtion issue.
Is their a WOT adjustment?
Might this be a powerhead/coil issue?
Could this simple be a throttle adjustment?
If you all could help out that would be great!
  #2
Old December 2nd, 2008, 09:32 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: Loss of RPM's at WOT, 90hp 1997
i'm assuming you have a Johnson. it could be as simple as a streched throttle cable, not moving the linkage to it's limit. it could be a simple coil failing, not producing spark to one cylinder. could be clogging carb jet. could be loss of compression on a cylinder or 2. also could be the bushing in the throttle linkage, wearing.
the bushing, pictured in the slot, is a 2 piece bushing, the outer has been know to crack or what ever and come off, leaving the inner. this allow play in the throttle linkage. i know this from experience on 2 motors.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old December 2nd, 2008, 09:56 AM
Default Re: Loss of RPM's at WOT, Evinrude 90hp 1997
Thanks for the reply, I'll check the bushing when I make it back home, but I don't believe thats the case, but I could be wrong. If it were a streched cable, how is one to identify that and how simple is the cure? Even back when it would get up to 5500 rpms, the throttle handle could be push farther forward approximately 2-3 inches where the engine wouldn't rev any higher and the throttle handle just seemed to have excessive forward play.
  #4
Old December 2nd, 2008, 10:02 AM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
That's not a 60* motor in that picture, don't be confused. There are a couple of things that could cause what you're describing. Perhaps the prop is venting which means the rpm will go up but you'll lose forward bite. The motor could be dropping a cylinder - coming and going.
  #5
Old December 2nd, 2008, 10:09 AM
Oh believe me I knew that wasn't the same as my motor as I have stared at it for hours on end, but it clearly showed his point of the bushing.
What do you mean by dropping a cylinder?
  #6
Old December 2nd, 2008, 10:21 AM
You may be losing spark to a cylinder intermittently, may have a partially clogged carb jet, may have cylinder damage. A good place to start is with a compression test, then check spark.
  #7
Old December 2nd, 2008, 05:56 PM
Compression test it will be for that's an easy freebie, it's also most likely time for a carb overhaul as now that I've been thinking about it, I do believe I may have ran some ancient age, oh I mean old gas at some point quite a while ago. Thanks for the ideas.
The excessive forward play in the throttle handle has always bothered me some, could that be partly due to a streched or improperly set-up cable?
  #8
Old December 2nd, 2008, 06:21 PM
yes.
__________________
FLORIDA GATORS
TEBOW Country
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Loss Of RPM's FORRESTP Mercury & Mariner Outboards 5 May 29th, 2007 08:24 PM
1997 90hp V4 Johnson correct WOT RPM's? dpski Johnson & Evinrude Outboards 1 July 19th, 2005 11:01 AM
WOT RPM's and cruising RPM's tony_cliffy Johnson & Evinrude Outboards 21 April 19th, 2004 11:07 AM
RPM's at WOT 92 90HP Force dcar00 Force & Chrysler Outboards 5 April 18th, 2004 08:21 PM
Loss of RPM's? bryanredfish Mercury & Mariner Outboards 2 August 21st, 2002 07:28 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
