  #1
Old December 2nd, 2008, 02:13 AM
csootsman csootsman is offline
Default mercury 70hp oil leak
Hello, I am new to the forums. A friend directed me here.
My question is I have a 87 I believe, 70hp mercury outboard. I just recently purchased it used. The motor runs great, however the other day I noticed that when I had the motor trimmed in the trailering position I noticed a small amount of what I believe to be gear oil seeping out of the water intake holes.
I have drained the gear oil and it was milky and I also noticed that I was missing a seal in the gearcase drain plug. I will be replacing the seals on the drain and vent plug, however the oil leaking from the water intake concerns me. What gasket and or seal would I most likely need to replace.
Thank you for your time
Clair Sootsman
  #2
Old December 2nd, 2008, 08:08 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: mercury 70hp oil leak
the oil may be normal. http://forums.iboats.com/showthread.php?t=207285. you are on the right track to renew the plug seal, and refill, then check it after a couple of runs. those seals are the #1 place for water intrusion. if you have water next time, you need to pressure check the lower, and find where it is leaking.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old December 17th, 2008, 02:18 PM
Ok, I replaced the drain plug gaskets. But I am still getting a small amount of water from somewhere. I just ordered a service manuel for this outboard. I am thinking that I need to replace some seals?. Also the gearcase looks fine , no cracks. I also pulled the prop and found no fishing line.
I am pretty handy with a wrench, does this sound like something I could do. Also before I start doe I need any special tools? Thanks
ps the ser#0B274515
  #4
Old December 17th, 2008, 04:00 PM
Chris1956 Chris1956 is offline
If gear oil is leaking from the water intakes, it is likely the waterpump base gasket, seals or oring is leaking. it is a fairly simple fix. You drop the lower unit, remove the cover of the water pump, remove the impeller, pry up the waterpump base and install a new base which has the new driveshaft seal installed in it, with a new gasket and oring. Now install a new stainless wearplate and it's two gaskets and a new impeller. Reeassemble the waterpump and reinstall the lower unit.
when you manual arrives, read the procedure, buy the parts and have at it.
  #5
Old December 17th, 2008, 05:10 PM
Thank you Chris, Now if I can go to the well one more time. Any suggestions to where I could get these parts online.
Clair
  #6
Old December 18th, 2008, 07:40 AM
Clair, Those parts are pretty common. Sierra, Merc and probably GLM make them. Try this site, try ebasicpower.com, try West Marine and Boaters World
A local Merc dealer is a good place since the cost will be pretty close to mailorder, but you will get the correct parts. Sometimes ordering the waterpump base is a challenge. You should inspect the upper waterpump housing for cracks and wear. Replace it is necessary.
  #7
Old December 18th, 2008, 09:02 AM
Thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
70hp Yamaha oil leak at prop Bubster71 Yamaha & Suzuki Outboards 5 October 3rd, 2009 08:17 PM
Mercury 150 Oil Leak shawn30 Mercury & Mariner Outboards 2 December 18th, 2007 04:47 PM
83 70hp Johnson Seahorse oil leak at prop alchik Johnson & Evinrude Outboards 2 August 10th, 2007 05:44 PM
Oil Filter Leak in Evenrude 4 stroke 2000 70hp Jim Melson Johnson & Evinrude Outboards 1 August 23rd, 2005 09:28 AM
4 stroke Mercury 5 HP oil leak.. theredboattoo Mercury & Mariner Outboards 0 August 1st, 2005 04:17 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
