Re: 02 yamaha 150hp compression test?
Correct procedure is to remove all spark plugs, Roger. The ignition can be disabled by pulling the kill lanyard or by simply leaving the key in OFF and operating the starter with a simple jumper at the solenoid.
Actual readings vary a lot because of differences in guages and technique, the important number being the spread of readings among the cylinders.
I would accept the readings you got as a healthy engine because you left the plugs in. With the plugs out you probably would have gotten readings a bit higher.
__________________
RED SKY at night. . .
JB
