Mercury 35hp no spark
rrwalker
My motor had been running fine until it suddenly quit (luckily I was near the boat ramp). I tested and found no spark on either plug. I disconnected the component that I think is the tilt switch but still no spark. (This component is about 1 3/4 inches long, cylinder-shaped, and has a lead wire from it that is screwed onto the side of the block. It sits at a 45 deg. angle.)
Hopefully someone can tell me what to do next and what equipment I will need.
Thanks
Robert Walker
Laddies
Banned
Re: Mercury 35hp no spark
We need a model year or serial number for the test info.
Laddies
Banned
You will need a minimum of a OHM meter, heres the test from CDI
