hey guys,
thanks in advance for your input. I recently let a buddy use my old 86 bayliner with a 50hp force(which you should never do :0) when i got the boat found a large chunk missing from the power head. I took the boat into the shop after I finally found a old power head with the exact model. I was just going to replace the rear part of the crankcase and hope for the best. but i figured i was going to sell the boat so i took it in for repair. when i took it in we found that a nut came off a coil pack and that is what caused the problem.
we found that the power head i purchased had low compression, from there i was told that we couldn't just replace the rear crankcase. Is this true?? the orginal motor was just rebuilt and had about 30hrs on it but am leary to just popping on the new crankcase.
should I just try it and see?
if it was a nut that caused the problem and end caps on the rods look fine would i need to disassmble the whole motor?
any help on this would be great
thanks for reading
James
thanks for reading
James
