Impeller Replacement
I have a 1993 nissan 3.5A-hp and I just finished rebuild of carb. I started it up today for the first time since I bought it two years ago. It fired up on the third pull but then noticed no stream of water, shut it down blew out hose and blasted a few shots of air from my compressor. Started it up again ran it for about 15-20 sec. no pee stream, had the motor in a barrel. So is there anything else to ck for?? It looks like in the manuel that replacing the impeller is a straight-forward job? The rebuild of carb was not that hard, but I have never replaced a impeller before, any advice would be helpful
Thanks for looking
The rookie
kandil
Re: Impeller Replacement
This one is very easy it is behind the prop nice;)
Kandil thanks for the reply its what I wanted to read. I will do the replacement this weekend!
