Re: 2000 Yamaha 250 bogging down over 1500rpms
There's a fine screen the the High pressure Fuel pump houseing.
Mine was clogged, I'll bet yours is too.
However, that only fixed it the first time,when it wouldn't get off plane.
I have the exact same engine , with the exact same symptoms (including the hitting wave)and can't run long distances over 3500rpms, The Harder it runs , the quicker it stalls.
It has 35psi of fuel pressure and 4in Hg of vacuum, which according some other advice is correct.
I'm thinking about , replacing the screen, even though it looks clean!
The Pumps is new.
The 3 fuel pumps are new.
The fuel filter is new.
Keep in touch.
Les
