mattbatten
- Sep 24, 2008
- 3
Hello..About a year ago i purchased a 19 ft carolina skiff with a 130 hp motor The previous owner had become ill for some time So the boat sat for a year maybe two, so the motor hardly has any hours on it..So i get the boat drain the fuel tank and try to fire it...The gas smelt horrible that had come out of it from sitting so i took it to the shop where i learned that a recall on the fuel system...The new system was installed....The boat run perfectly for two fishing tripps..on the third, i run around 6 miles and fished when i went to fire it up it wouldnt the boat idled back to the bank...Back to the shop...The Respectable Mechanic said to me that the plugs were bad and that he had tested the boat and put new plugs in....i dropped it in the water..The ball wouldnt get tight so i noticed the o-ring on the fuel line was bad..So i went to the shop I bought a new 3/8 hose and primer ball and new ends , the fuel filter is clean, I put it all new, filled up the tank and went back to the lake in the water the boat at first went perfectly up on plane plenty power...i circled slowed down took off again small hesitation which worsened by the end it seemed to help get it on plane if i pumped the ball, but once it was on plane it would opened up and run fine at 5000rpms for miles but after i stopped same thing like it was starving for gas....People have said to run a can of seafoam through it...any advice would be greatly appreciated
