I am looking to buy a 2004 17 foot Lund Explorer with a 115 Optimax on it. We took it for a test drive the other day and at idle it is 1000 RPM. Listening to it seemed a little high but not really. At about 50 percent throttle we reached 6000 RPM and about 25MPH. We still had plenty of throttle left and at top end tach was pegged and we were doing about 40MPH. The motor does not sound like it has excessive RPM at top end. Guessing from the tach reading at 50 percent throttle if you trusted the tach there would have been about 9000 RPM at top end. Max for a optimax should be 5750 RPM. If the switch setting is incorrect on the tach I am guessing it would be proportionally off. I am on the right path or not? Any suggestions would be appreciated. I did check the prop and it appears to be the factory prop and does have a ding or two on it but nothing major.
Thanks
Thanks
