Need info on 25 HP Mariner
hsteph
Hello, I am new to boating and have bought a old 16ft fiberglass boat with a 25hp Mariner. The motor runs ok, but needs a prop and a tune up. I would also like to replace the water pump ( don't know when it was last changed). The data tag is gone off the side of the motor. The only numbers that i have are off a hand writen note from many years ago 318161. How would I check to see if these are good numbers? I've gone to the sites that I have found on here, but don't see a match. The motor is a Mariner 25hp, 20 inch shaft, pull start. Is there another way to tell the year, ie somewhere else on the motor? Any help or guidance would be great. Thanks
hamit59
Re: Need info on 25 HP Mariner
Hi i don't see any other way to find out what your serial number is by the book i know on my older merc it has a seal that has the the serial on it.
i did look up the part number for an international 25 hp 25 hp merc a mariner the part number for the on018456 and up were the same to the last serial i found which covers the 30 hp mariner
part number is 853792a1
http://www.mercruiserparts.com
you can look at this link and look for yourself
i hope this helps
