Rodbolt since you are the Yamaha guru here I am asking for your opinion on this.
I have a 25 msh yamaha engine that doesn't like starting cold. Starts & runs great no problems other than cold starting. It seems that the choke plates are not being closed all the way when the choke knob is pulled out. As per yamaha rta ,I replaced the entire assembly ( all links, bushings and knob). Still has same problem. The bottom carb has two parts one which the link between both carbs attaches and the other is where the choke knob link attaches.The choke knob link will not travel far enough to completely close the choke plates. when choked all the way I have a very noticeable gap in the plates.
I would very much appreciate your opinion on this. It is also the second 25 msh to have this problem. Thanks
http://i4.photobucket.com/albums/y12...S6301522-1.jpg
