evinrude4300
- Jul 30, 2008
- 2
I have a '67 9.5, when first purchased motor it ran great and planed my 14' aluminum jon easily. Started having "power" issues so... I rebuilt the carb, installed a new fuel pump, new fuel tank, fuel lines from connector to pump and from pump to carb, tank line, filter on tank plus new lower unit with water pump housing and associated parts, also tuned with resetting of existing points and new plugs. Also replaced the prop hub and even tried a different pitch and diameter prop with no luck. The motor starts easily, idles like a sewing machine and trolls like a champ. However, when powering up it takes a long time to reach what speed it can produce. Also, since all of this, I seem to have lost power as the boat can barely plane. It seems as if the motor wants to go more but just cannot get there. Am I missing the obvious here?? I am starting to believe the "if it ain't broke don't fix it mantra". Any and all suggestions would be appreciated. Forgot to mention, compression (65, 70) and spark is good on both cylinders.
