  #1
Old November 24th, 2008, 11:09 AM
fsutim fsutim is offline
Default Yamaha 1988 130HP Idle Mixture Screw Settings
I began rebuilding my Carburetors this weekend and got ahead of myself and took out the idle mixture screws for one set of my carburetors. The problem was I didn't mark where the screws were before they were unscrewed. Any insight as to how these screws are supposed to be seated? I installed the carbs back on the engine and its running on high RPMs but will stall when you try to idle. I have attached an illustrated picture of the idle mixture screws that were removed in figure A of the attached picture. Could someone please help me with getting these screws adjusted.
Thanks!
- Tim
  #2
Old November 24th, 2008, 12:41 PM
cousinabe's Avatar
cousinabe cousinabe is offline
Default Re: Yamaha 1988 130HP Idle Mixture Screw Settings
Tune up Guide says 7/8 turn and timing at -5 degrees (5 ATDC)
  #3
Old November 24th, 2008, 12:59 PM
Could you please describe what "7/8 turn" means?
Thanks!
  #4
Old November 24th, 2008, 01:11 PM
cousinabe's Avatar
turn the screw in all the way till it lightly seats. then turn out 7/8 turn.
8/8 would be a full turn out... so a little less than 1 full turn out from seated.
  #5
Old November 24th, 2008, 01:25 PM
Thanks for the clarification. Just to confirm, Is it lightly seated when I first start feeling resistance while turning the screw? The reason why I ask is there is a spring on the end of the screw and I imagine I could get about 5 complete turns after I start to feel the resistance that the spring causes.
  #6
Old November 24th, 2008, 08:18 PM
cousinabe's Avatar
no. lightly seated means all the way in till you can't turn no more... past the five turns of the spring engagement.
  #7
Old November 24th, 2008, 09:13 PM
douglloyd douglloyd is offline
The trick is not to scar the brass adjusting screw or the seat. You don't want to gaul the needle, if it is already by visual inspection get new or it will never be right.
  #8
Old November 25th, 2008, 09:07 AM
Perfect, Thanks for all the help. Hopefully I will get this engine purring again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Carb Mixture Screw Settings 85 60 HP Merc MadKatter Mercury & Mariner Outboards 3 June 16th, 2008 02:55 AM
1987 Yamaha 9.9: Where is the Idle Fuel Mixture screw? (pic) ST Yamaha & Suzuki Outboards 5 April 16th, 2006 03:02 PM
Suzuki DT75 idle screw settings Richard Aitken Boat Topics and Questions (not engine topics) 1 September 28th, 2005 08:21 PM
Suzuki DT75 idle screw settings Richard Aitken Yamaha & Suzuki Outboards 1 September 28th, 2005 08:21 PM
Idle screw settings Snoopy Yamaha & Suzuki Outboards 3 March 7th, 2003 12:41 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
