sportpilot
- Aug 7, 2008
- 16
Thanks to some help I got on this forum, I have finally got this boat in shape enough to start tuning...
So, from the beginning...I have a 1996 Stratos 278 with an 1994 Evinrude 120 V4. Currently have the engine mounted to a CMC ML-65 jack plate. I have had the luxury of testing two props on this unit so far, but feel that I should be running a little faster and need some help to optimize...
1: OMC 13 7/8 x 19 Viper the boat is running 48 mph (GPS) with driver, passenger and full load of fuel at just over 6200 RPM WOT. Great hole shot (less than a boat length) and acceleration. 14% slip.
2: OMC 13 1/2 x 22 Raker the boat is running 49 mph (GPS) with driver, passenger and full load of fuel at just over 5600 RPM WOT. Hole shot is about 3 boat lengths and acceleration is slower than Viper. 16% slip.
I currently have the prop shaft height at 3" below the bottom of the boat and the AV plate is about 4" above the bottom of the boat. I can trim both props up a little past level before they start to lose their bite with the Raker holding in longer (with one heck of a rooster tail). No problems with ater pressure at current height setting. It holds a strong 6 psi at idle and almost 30 at WOT.
Should this hull and motor combination be running faster or am I about peaked out? I am thinking of trying a 20 Raker or 21 Viper but wanted some input on this setup from you guys beforehand...both of these props seem to have excessive slip compared to what I have read on here...
The boat runs great and it really feels like something nice is about to happen when it gets close to the 50 mark...you can feel it start to lift up that final little bit, but just doesn't make it. There is a little chine walking between 45 and 49 mph. I just think this boat should be running in the mid 50's with this setup, but maybe my looper isn't as strong as it once was...
All input very welcome and I can't wait to hear back from you guys...
