  #1
Old November 23rd, 2008, 08:58 PM
joho5 joho5 is offline
Default 1976 Evinrude 15hp inspection
Well I just got the motor today, here is what I found.
note: the guy told me it was firing only on 1 cylinder.
1. the first thing I checked was the spark plugs to see if they were getting spark and both were, which was weird.
2. there is a small chip out of the flywheel, about half an inch.
3. I was going to inspect the ignition components under the flywheel but couldnt get it off with my puller. I tried for a couple of hours and gave up. One of the threads has been stripped, but had threads down in there, so I could get a bolt in there, it was just rough at the top. I tightened, knocked, tapped, tightened till it wouldnt tighten any more. I will have to mess with that later.
4. the screen in the fuel pump has some red, rusty looking stuff in it. maybe its what gas looks like when its dried up, I dont know. I cleaned that with carb cleaner and sprayed a bit in the fuel pump.
now, i was going to wait and clean the carb and put a new impeller in, but I couldnt stand it. I loaded it up and took it to the lake.
It started on first pull choked, and then started on next with no choke. Idled down real quiet.
it ran good at top end and sounded good, but there was a couple of problems I found.
when I twist the throttle all the way down, it will die. Come to look at it though, when its twisted all the way to slow, the cam is not even touching the roller from the carb. Is that correct?
when its throttled down, should the cam actually loose contact with the roller because it goes over so far?
  #2
Old November 23rd, 2008, 09:07 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 1976 Evinrude 15hp inspection
tillers are suppose to die when throttled all the way back.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old November 23rd, 2008, 09:11 PM
Benny1963's Avatar
Benny1963 Benny1963 is offline
better soak them carbs and do that waterpump
__________________
Benny B
  #4
Old November 23rd, 2008, 09:48 PM
jbjennings's Avatar
jbjennings jbjennings is offline
I believe that model has an adjustment on the side behind the fuel hose attachment that you can adjust. I believe its an idle stop type thing. Part #37 on the diagram I've linked you to. If I remember right, you can turn that dial and your throttle grip won't be able to back the armature plate far enough to kill it and you'll have to cut it off with the kill button. But your carb could be dirty, too, and that's why it's dying on you. I believe the roller should come off the cam a short distance when throttled down all the way.
Just an idea,
JBJ
BTW, I'm with Benny on the impeller and carb cleaning/tank cleaning thing. I believe your tank may be rusty and that's what you found on the filter if you have a metal tank. You can only clean a carb by taking it all the way apart and cleaning it, cleaning/blowing out all the passages. I'd definitely do it especially if you can't get it just like you want it with the idle stop adjustment on the side.
http://www.crowleymarine.com/brp_par...rams/29572.cfm
Last edited by jbjennings : November 23rd, 2008 at 09:53 PM. Reason: I must be dyslexic
  #5
Old November 23rd, 2008, 10:35 PM
Yea, I have totally restored a 71 9.5, but it didnt come off the cam like this one is doing. If it is supposed to die when not throttled at all, I am fine with that.
Thats the first thing I am going to do is overhaul / clean the carb, and get a new impeller.
I want to be able to pull the flywheel to look under there and just for future.
When these things are stuck on there, do you guys use a penetrating lube or what to help them? and I know I guess I should let it sit over night.
  #6
Old November 23rd, 2008, 10:45 PM
Rick. Rick. is offline
Congratulations on your first outing. Many motors perform much worse when they've just changed hands. That part # 37 is great for setting a trolling speed that you can use as a reference after you stop the engine or change locations, you can throttle back to the exact speed you were going previously. You have been given good advise above. In the FAQ part of this site there is an article about "awakening an outboard" and several articles written by a Leroy Wiesner (sp). Read them both and many of the others for that matter. You mentioned spraying carb. cleaner in your fuel pump. I would never do that as carb cleaner can damage plastics and man made materials. Use it on brass and any metal but be very careful where else you use it. The chip out of the flywheel could cause it to be out of balance but you can decide if it's a problem. Are you using a harmonic balancer puller that has bolts going to all three holes? You should be. I can only suggest tightening it as tight as you think you dare and leaving it for a time and then tighten it some more and leave it again.( even over night if necessary) A rap with a hammer on the center bolt might be what's required. The readers on this site are a great bunch and will get you through most any problem but you would be doing yourself a favor if you bought a factory service manual. Good luck. Rick.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
15hp 1976 evinrude fuel pump help kingfish999 Johnson & Evinrude Outboards 1 July 12th, 2007 05:01 PM
Rebuilding a 1976 15HP Johnson DaveInGA Johnson & Evinrude Outboards 6 July 10th, 2007 06:59 AM
1976 15hp lean tdp63 Johnson & Evinrude Outboards 2 March 18th, 2007 11:53 PM
evinrude 9.9-15hp gasket 1974-1976 herters Johnson & Evinrude Outboards 1 August 6th, 2004 06:31 AM
1976 Evinrude 15Hp Long shaft w/ poor reverse power dsta Johnson & Evinrude Outboards 7 June 3rd, 2003 11:20 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
