  #1
Old November 23rd, 2008, 05:53 PM
RyanDavidge RyanDavidge is offline
Default Mercury XR2 Cooling
I just got a Mercury XR2 on a Phantom 21. When I run it on land with the fresh water hook-up the water doesn't come out of the block very fast (dribbles) when I took apart the fixture that attaches to the block, there is something that looks like a washer with a hole about 3/8" in the middle. The boat was from england, so i'm guessing this is because the water is cooler, so not as large a flow is needed???? The boat is now in warmer water, so should I just remove the washer type things? I figure the more water the better... Thoughts please.
  #2
Old November 23rd, 2008, 10:36 PM
yamamarinetech40 yamamarinetech40 is offline
Default Re: Mercury XR2 Cooling
I think you are being paranoid, unless there's something you aren't saying....you've had no problems with overheating by your post, no alarms, nothing...so what's the problem? DON'T remove the washer or you will have though, it seals out the air, if you draw a touch of air into the system, it'll travel to pump and....overheating will follow. You want your water pressure to be good, not above 45 psi and not too low. If the alarm is in working order you shouldn't be thinking about all this....
  #3
Old November 24th, 2008, 10:44 AM
Chris1956 Chris1956 is offline
Ryan, The telltale may be clogged or connected to the out flow of the thermostats. At idle in neutral, the thermostats may not open. Does water come out of the prop hub? Does it come out of the grating above the antiventilation plate? If so, the waterpump is working.
Don't modify the cooling system, unless you know exactly what you are doing. You may replace the two thermostats, and the waterpump impeller if you like. Repair the poppet if you want, but don't remove it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury 150 XR2 chadbenton Mercury & Mariner Outboards 8 August 4th, 2008 01:23 PM
Weight of a `87 Mercury B.M. XR2 150 vs. `01 Mercury Optimax 225 hp ?? PasseLat Mercury & Mariner Outboards 2 May 13th, 2008 07:59 PM
Mercury XR2 icr2 Mercury & Mariner Outboards 0 July 19th, 2005 11:13 AM
MERCURY XR2 SALTWATER Mercury & Mariner Outboards 0 July 21st, 2003 06:05 AM
Mercury XR2 Problem neckman Mercury & Mariner Outboards 1 July 18th, 2003 08:33 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
