50 Hp Johnson J50PLSSM- Spark on 1 cyl. only
electra05
No spark on upper cylinder. Wire coming from engine to a single pin connector has grounded out and arced on frame. This went through the insulation of the wire. I put tape on it, but was wondering if this could have caused my problem and destroyed something else. Any suggestions?
PS.. Plugs and wires are good.
tashasdaddy
Re: 50 Hp Johnson J50PLSSM- Spark on 1 cyl. only
completely swap the coils, and see it the no spark follow the coil, if so replace the coil. replace wire also.
