my problem is the motor is running roughand it dies sometimes. i change the sparke plugs and the fuel bulb. one day i could go out and it will run all day and today i made it out of the channel and it died and wouldnt start and i had to prime it with the key and fast idle it 3 or 4 times befor it would stay running , but when it does run good the motor shakes hard and sputters. should the fuel bulb be hard or soft when the motor is running , because it is soft , plus where is the fuel filter? i see i white 1.5 cylinder with a inlet and outlet is that the filter any advice would help
thank u
mcruea
thank u
mcruea
