  #1
Old November 19th, 2008, 03:31 AM
allterrain2000 allterrain2000 is offline
Default Mercury 15hp fuel not presurising please help!
Ok I am new to the forum and I have a couple of questions. I have a 2002 Mercury 15hp short shaft two stroke. When i bought it, it was really hard to start it would fire up second pull then stall then it was 15 or so pulls until it got going.
I put it in for a full service and told when I picked it up it had a little bit of water in the fuel which may have been the problem.
So last week I go to take it out, it still has the same starting problem. But now when it gets going it will only go to 1/4 throttle and it dies. I then went to feel the bulb and its soft and wont pump up hard? I changed fuel lines and fuel tank and no difference.
took it back to the boat bloke last week and spoke to him today said it has got him stumped, he said he is replacing the diaphram in the fuel pump but it looks ok though. So can someone help? I said to him how is it that it didn't have the problem before service and now after I pay my couple of hundred for a service its stuffed? He said wouldn't have anything to do with the service, I say rubbish.
Please help
Cheers
Jase
  #2
Old November 19th, 2008, 04:00 AM
Dunaruna's Avatar
Dunaruna Dunaruna is offline
Send a message via Skype™ to Dunaruna
Default Re: Mercury 15hp fuel not presurising please help!
The bulb has a check valve in it (that's why there is an arrow). Sounds like it is stuck open.
__________________
Watch this space......................
  #3
Old November 19th, 2008, 07:19 AM
rightcoastrob rightcoastrob is offline
I had this same issue with a Attwood bulb that was brand new.After i rebuilt my fuel pump thought.So at the ramp i proceed to take apart my fuel pump in about 90 noon sun.Just knew i put the check valves in backwards...Long story short i dropped a check valve in the water had to drive60 miles and spend 50 extra bucks to replace a new 5$ primer bulb.If it was me i would tell that guy to start there and take it off the hundred bucks he owes you lol.SAve your money and do the fuel pump yourself there simple.Just dont do it at the ramp in the water.....
__________________
spun my props long ago
  #4
Old November 19th, 2008, 07:43 AM
Thanks for the replies guys but no its not the bulb, as stated I swapped my tank and fuel line with a mates who has exactly the same motor and it was still doing the same thing. His tank and fuel line work fine on his motor and my tank and fuel line also worked fine on his motor but not mine so its somewhere in the fuel system.
Cheers
Jase
  #5
Old November 19th, 2008, 09:37 AM
Laddies Laddies is offline
Either the fuel pump diaphram fas a hole in it ot the inlet is leaking, they are both in the carb so get a kit and rebuild the carb.
  #6
Old November 19th, 2008, 08:42 PM
Thanks for that laddies, the boat bloke is going to replace the diaphram so will see if that fixes the problem.
Cheers
Jase
  #7
Old November 19th, 2008, 10:06 PM
yamamarinetech40 yamamarinetech40 is offline
This is very simple, the water in the fuel has gummed up the carb(or varnish) and the needle is stuck open, so fuel passes through although float is up...but motor won't run due to jets being gummed also....best guess.
  #8
Old November 20th, 2008, 06:19 PM
sschefer sschefer is offline
3 months ago I changed the fuel filter on my Nissan 18 and afterwards the bulb would not fill no mater how many times I pumped it. I could see fuel in the pump and the filter and I ran it on the lake just fine over the next couple of months.
Before I put it away for the winter I changed the oil, filters, impeller and greese. Low an behold the bulb pumped up fine. As a test, I put the other fuel filter in and the bulb went back to being a problem again.
In my case it was definitely a defective fuel filter. I'm guessing theres a check valve in my filter also.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Need help on 15HP mercury. WOT RPM? rafiqi Mercury & Mariner Outboards 2 November 21st, 2008 09:16 AM
help with a mercury xr2 fuel problem? ronnydean Mercury & Mariner Outboards 3 September 12th, 2008 01:23 PM
15hp 1976 evinrude fuel pump help kingfish999 Johnson & Evinrude Outboards 1 July 12th, 2007 05:01 PM
help with new Mercury 15hp 2-stroke C Perini Mercury & Mariner Outboards 2 August 19th, 2004 06:46 PM
15HP MERCURY TACH HELP wjjb Mercury & Mariner Outboards 0 May 21st, 2003 10:16 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
