AguaSki
- Jul 4, 2005
- 545
Ever since I have owned my boat I have had a difficult time getting to the desired 5,800 RPM at WOT. My motor is a 1978 140 hp Johnson on a 1978, 18 foot Glastron SSV-188. Both the motor and the boat are in great condition. I am turning a 15 pitch SS Apollo prop. The best RPM's I have seen are about 5,480 during the cool spring months. As the weather warmed, and the air became more humid I lost a little RPM off my best, but I have noticed those lost RPM's starting to come back as the summer temps ease. Last Saturday I was about 5,380 RPM.
This is what I have done to get my RPM's up:
? Raised the motor 2 holes (also installed a water pressure gauge)
? Checked compression (all four are within a few pounds of 120 psi)
? Replaced the tach twice (current tach is a digital OMC)
? Installed unlimited RPM CDI power pack's from iBoats
? Rebuilt the entire fuel system including draining the tank, rebuilding the carb's (linkage & synch included), new fuel pump, replaced every hose inside and outside of the cowl, and installed a new water/fuel separating filter.
? Replaced throttle cables
? Installed Smart Tabs
? Annual decarb
Not everything noted above was done in a direct attempt to get the RPM's up, but all should be contributing to the performance I am looking for
The motor purrs like a kitten at low rpm's, jumps on a plane when the throttle is applied, easily pulls me up on a slalom ski, and tops out around 36-37 mph (GPS verified). I really can't think of anything to complain about in my performance at any of the RPM ranges.
I can't think of anything else to check on the motor, so I want to verify I am not hauling around extra water weight. When I bought the boat it came with a test wheel. I have never used a test wheel before, but I am thinking about installing it the next time I am at the lake, and then turning the throttle loose with the boat still strapped to the trailer. If the engine winds up near the 5,800 RPM mark with the test wheel installed, then I will guess that I am carrying extra water weight under my floor. If the motor will not get near 5,800 RPM, then I know to keep looking at the motor. Will running the motor at WOT using a test wheel with the boat still on trailer give me an accurate RPM reading?
? Annual decarb
