I just rebuilt the motor (seals, bearings, rings, water pump, head job, everything) I broke it in somewhat in the yard with a earphone? hooked up to the waterhose. I did the 1/4 throtle for 5 min, then cooldown, then little more than 1/4 throttle for 5 min then cooldown etc.... I took it out today and the thing was overheating to the point that it would not crank after I shut it down from the smoke that was billowing from the engine. By the way it's a 1998 Mariner bigfoot 50 4 stroke. I took the thermostat out and it still runs hot?! I cleaned out the ports under the powerhead and replace the mounting gasket. I have a strong stream of water out the pee hole. I'm befuddled!?>!?!?!!?!? Help PLEASE!>...
