es_bob
- Jul 4, 2007
- 30
Hello all,
I am in need of some help / information and I am hoping you guys can help. I have a 74 Glastron v156 with a Johnson 85hp on it. The model is 85ESL74. Motor has run great over its lifespan, but this year it is telling me it needs work. The 1st time I took it out this year it started up fairly good. 2nd time it was real good. 3rd time I took it out it was a bear to start... I notice that there is gas inside (under) the hood, looks like it is seeping out of one of the carbs.
I know that the carbs were never messed with (to my Dad's knowledge, was his boat since new in 74). Where can I find parts for this thing? I'd like to change the floats, needles, gaskets, and whatever else you would recommend. I am not sure if the hard starting has to do with the gas leak, but I'd think that COULD play into it. Also, when I go wide open from a stop I get a hiccup, then she takes off. Sometimes it loads up pretty bad when doing a sudden wide open throttle.
Also, what about the fuel filter? Where can I find that? I'm looking for recommendations and how deep I'll be if I do this myself. I've worked on snowmobile and lawnmower carbs before so they don't scare me. I also have the 74 service manual for this specific motor.
Thanks in advance!
-Bob
Thanks in advance!
-Bob
