  #1
Old November 16th, 2008, 04:20 PM
dswanson79 dswanson79 is offline
Default Mercury Lower unit fit problem
I bought a used lower unit from the same year and hp as mine a 115 4cyl. mercury force. I installed a new impeller kit and went to put the lower unit on the motor and found that both the motor and lower unit have a silver metal tube coming out of the same spot (looks like the speedometer pickup its just in front of the f-n-r shaft) I need to take one of them out so that the lower unit will slip on flush with the motor. I gently tried removing after applying wd40 with no luck. Is there a trick to getting it off?
  #2
Old November 16th, 2008, 06:22 PM
bchoate bchoate is offline
Default Re: Mercury Lower unit fit problem
These dowel pins do stick pretty good due to tight tolerances/corrosion.
You might have to use a little heat to it (preferably the one in the exhaust housing, leave the one in the lower unit, if possible.) and use vise grips or linemans pliers to twist and pull down. Hope this helps.
  #3
Old November 16th, 2008, 09:37 PM
Added a little heat and it came right out. Thanks for the help!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1978 140HP Evinrude with seized lower unit - other damage? - Which lower units fit? colpaz Johnson & Evinrude Outboards 4 June 12th, 2008 05:40 PM
does Pre-Alfa lower unit fit with A1 gen1 uper unit? sarantis Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 August 29th, 2007 08:06 PM
Will a MR lower unit fit where a R unit used too?? ottawamerc Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 October 4th, 2006 09:32 AM
Will 1983 mercury 25hp lower unit fit 1987 model? clintb Mercury & Mariner Outboards 5 February 4th, 2004 03:39 PM
Will a 1967 100 mercury lower unit fit on a 1971 80 H.P. Rex Mercury & Mariner Outboards 0 November 11th, 2002 04:55 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
